Sold/Expired Lenslight KO Copper Dual Mode - SOLD
Scotcha
Australia
The light is brand new. I purchased it on the 26th of June from Blue Line Gear and it has been sitting in a drawer. Perfect condition. It was lightly polished to remove patina once.
Light works on 2 x CR123's or 2 x RCR123's or one 16650
Two Modes
Output (Lumens):
440 (High) 5 (Low)
Runtime (Hours):
2.2 (High) 60 (Low)
Some Info from Lenslight :
1) High Impact Hardened Optical Glass Lenses ? protects the LED from the toughest of conditions and diligently bends the light much like a magnifying glass to ensure maximum brightness, distance, and efficiency. But don?t let the durability of a glass lens fool you, these lenses have been vigorously tested and designed to withstand excessive abuse while retaining optimal performance.
2) Patented Focusing Aspherical Lens System ? This patented technology allows for a significant array of focusing options ranging from a flood to spot beam. This ensures that the perfect focus setting is available whether you are concentrating the light hundreds of yards away, or simply lighting up an object nearby.
3) McClicky Momentary Activation On/Off Switch ? This reliable easy to use tailcap switch enables the LensLight Mini?s 2-stage microprocessor to power the flashlight at either an efficient low setting or high output level for maximum brightness. Simply press down once for low setting, press again for high setting, or simply press all the way down for constant-on.
4) Light Emitting Diode ?A premium exclusive high-tech, high-efficiency LED is used to emit astonishing power that is untouchable by any other light. This everlasting LED is sure to exert enough luminosity to stop any and everything in its track. Now that?s what you call an LED!
5) Premium Grade O-Rings- LensLight Mini contains 6 strategically placed O-rings throughout the flashlight to seal and protect the lights internals from dust, moisture, and any other micro-substance that it may come in contact with. This ensures that the LensLight performs at maximum efficiency at all times and your investment last a lifetime.
Titanium Pocket Clip
Patented Focusable Aspheric Lens System
TypeIII hard anodize 7075 Aluminum
High Tolerance American CNC Machining
Double Lens - high impact hardened glass
Chem-Kote Contacts and Heat sink
Aerospace Grade Thermal Potting and Flow Management
Weather Proof/Water Resistant
Premium Bin High CRI CREE XPG-2 LED
Fully Regulated Light Engine
Will ship worldwide via Australia Post with Tracking.
List Date: 12/23/2015
For more info, click here to view the original listing: Lenslight KO Copper Dual Mode
SOLD
candlepowerforums
Scotcha
Australia
Not sure how to contact the buyer here but I have emailed the tracking number to your email address provided by paypal.
