Lingwendil
- Joined
- Dec 24, 2015
- Messages
- 9
Hey all, first post.
So, i recently wrecked my daily driver 61 Baja Bug, and a buddy gave me a 91 Cadillac Seville STS, and the low-beam lighting is absolutely terrible. i feel like i can barely see the road. hi-beam works great, and in this model there are four separate 9004 bulbs in individual compartments for lighting up the headlamps, each only firing half the bulb. I had a spare brand new pair of 9004 philips bulbs (the basic pair for cheap at all the auto parts stores, forget the specifics, its been a while, they were only used once, then put away) that i swapped in and it made no difference. i parked the car in the warehouse at work (level surface with a flat wall to point at) and verified that they are aimed appropriately. the headlight housings look practically brand new, are made of glass, and the reflectors are clean, no hazing or fogginess at all. I know better than to add supplemental (snake oil) fixes like HID kits, fog lamps, etc. I get 14.29 volts at my battery, and 14.22 volts at the socket, engine running, so i don´t believe a relay would be necessary...
Will a pair of Xtravision or Silverstar bulbs be worth the money? Any other suggestions?
My Baja had Cibie Z-beams, so am I just spoiled? that car had the best lighting of any car i´ve ever driven.
Here´s the car in question, btw...
