Fenix Outfitters
Results 1 to 19 of 19
Thread: Smallest & most powerful compact Light?
    Help Smallest & most powerful compact Light?
    Just got a Nitecore P12 and I love it but am wondering what the smallest most powerful light actually is? Am looking for something the width of the P12 but shorter?
    I do know Olight makes some which are about 3.5" but those are also about 2.6" wide which I don't care for!
    Thanks
    Flashaholic* Tejasandre's Avatar
    Jul 2015
    SA, TX, UsA
    Default Re: Smallest & most powerful compact Light?
    ToolVN
    Flashaholic* Ryp's Avatar
    Jul 2013
    Nitecore EC11
    ven's Avatar
    Oct 2013
    Manchester UK
    Quote Originally Posted by Tejasandre View Post
    ToolVN
    +1, its got to be well up there as the smallest and most powerful............more importantly actually usable power too without ridiculous heat in a couple of seconds........
    May be too small though ..........as 10440 fed which is AAA size but of course 4.2v
    Nitecore EC11
    I opted for the MT10C myself, though it's very similar to the EC11. I just got it yesterday and found it to have a near perfect size and it's just as bright as my P12 - and the UI is much better than the P12.
    *Flashaholic* Str8stroke's Avatar
    Nov 2013
    On The Black Pearl
    Tough question when you say "smallest". DQG spy? or something like a TNC Micro Lux Turbo maybe?
    Interested in Saltytri lights. Pm me!
    Flashaholic* Timothybil's Avatar
    Nov 2007
    The great state of Iowa
    Nitecore EC11
    The EA11 also. The body is slightly thinner, but the head and tail cap are the same as on the EC11. With a regular AA cell it will do about 160 lumens on turbo, but with a 14500 IMR it jumps up to 900. Only for about 30 minutes though.
    Remember, Two is One, and One is None!.
    Thanks to all, the ToolVN I like best but very $$ and from what I see is made by 1 person and wonder how long will be in business? The one I decided on is the Nitecore EC11 but I do wonder if it takes normal CR 123A batt (says CR123 so I guess its different from a CR123A) ?
    Also if I get the EC11 can I use my batt charger for my 18650 to charge the EC11 18350 batteries?
    Thanks
    Nov 2013
    On The Black Pearl
    CR123 is same thing.
    most 18650 chargers will work just fine. Assuming the cell fits length wise. What charger you have?
    Thanks just wanted to be sure! I have the Nitecore UM10 and the Intelli Charger I2, however after "Shining" if I put my 18650 in the UM10 it shows the batt% like say 68% then switches to EE which means (bad batt) but in the other which only has 3 lights it will charge at once.
    If I wait about 30 min and let batt cool then the UM10 will read % and charge, which is weird?
    MT10A on a single 14500 IMR cell puts out 1000 lumens... Remember throw and spill can make other lights more effective for your use.
    Nov 2013
    On The Black Pearl
    Strange, I have both of those chargers. Never experienced that. What kind of battery are you using? Make, model, age and so on. Have you tried other batteries?
    Quote Originally Posted by Str8stroke View Post
    All I have is 2 Nitecore 18650 batteries 2300mah and are new came in bundle with light for Christmas.
    On the 18350 for the EC11 light I cant find any Nitecore batt higher than 750mah, but other brands come much higher?
    Nov 2007
    750 mAh sounds reasonable for an 18350. I don't recall ever seeing an 18350 rated at more than 1000 mAh, but I'm an old fart and my mind may be going. (How can I tell?)
    A Convoy S2+ 18350 with triple XP-L is probably brightest for its size. Should put out close to 3000 lumens.
    The Olight S1 is about as small as you can get. . . Yet it can put out 500 lumens and has good run times.
    Bill
    Pacific NW
    ven's Avatar
    Oct 2013
    Manchester UK
    Quote Originally Posted by joebob4501 View Post
    Good suggestion sticking with 18650 will give it higher output on direct drive due to higher A 18650's compared to more limited 18350's. The 18650 body is still a compact light imo, quite short and not that wide.........The 18350 is a real compact monster!
    18350 size
    Flashaholic* KeepingItLight's Avatar
    May 2015
    California
    It must be fun to casually hand one of those S2+ shorties to a non-flashaholic, and say, "Check this out..."
    BAM!!!!
    Of course, you have to make sure your friend is not staring into the business end when the light show begins.
    Prince plays George Harrison's masterpiece While My Guitar Gently Weeps. R.I.P.
    Great vocals & guitar by LeAnn Rimes & Joss Stone as they cover Gershwin's Summertime.
    ven's Avatar
    Oct 2013
    Manchester UK
    Quote Originally Posted by KeepingItLight View Post
    BAM!!!!
    But you said FUN!!!
    Ok i am mean
