HDS Systems
Results 1 to 13 of 13
Thread: K50V3 CREE XHP35 HI 2500LM Throw 1300M
    Flashaholic LessDark's Avatar
    Dec 2013
    Norway
    Default K50V3 CREE XHP35 HI 2500LM Throw 1300M
    Hello Acebeam,
    Do you have any info to share on this new monster thrower of yours?
    Warm white.
    Default Re: K50V3 CREE XHP35 HI 2500LM Throw 1300M
    I just noticed this on the Acebeam website. I am not as savy and up-to-date with all the new led emitters out there so this is the first time I am learning about the Cree XHP35 led. According to Cree specifications, the XHP35 is 3.45mm x 3.45mm (which is the same dimension as the XPl-HI). As far as I knew, the Cree XPL-HI was the top dog for throw, but the XHP35 looks very promising as well. Although the XHP35 has a dome, it can produce higher lumens than the XPL-HI.
    I gotta say this looks very interesting. I already have an Olight M3XS-UT, but if the price is right, I may end up getting the K50V3 as I want another flashlight that can throw far.
    Flashaholic* Tac Gunner's Avatar
    Oct 2012
    Bluegrass Region of KY
    Quote Originally Posted by Summer Heat View Post
    Actually I believe they are using the HI model XHP35 so there is no dome which will give a tighter beam angle
    Reliability, NW and moonlight mode, the most important factors in a light
    Flashaholic* Overclocker's Avatar
    Aug 2005
    Philippines
    seems like an overclocked LED. this is gonna be awesome
    Quote Originally Posted by Tac Gunner View Post
    Oh wow. I did not even notice that until I took a look back at the Cree lineup and found the XHP35-HI. With that kind of led emitter combined with a large and deep reflector, I am hoping this K50V3 can surpass 300,000 candela. That would be amazing for a stock flashlight.
    Unenlightened
    Feb 2016
    Denmark
    Here is some more info on Acebeam K50v3:
    The K50v3 comes in a nice Box with 12V and 230V magnetic charger, holster, lanyard and O-rings.
    Working voltage: 10V to 17V
    Max 2600 lumens
    Peak beam intensity: 422.000 Candela !!!
    Max beam distance: 1300 meters.
    Size: L = 203,5mm B = 90,2/52,5mm
    Weight: 644g with the battery holder.
    IPX8 standart 2M.
    Runtime with 4 pcs. 3400 mAh 18650 Batteries with PCB:
    Level 1: 1 lumen 1200 Hours
    Level 2: 70 lumen 75 Hours
    Level 3: 450 lumen 12 Hours
    Level 4: 1000 lumen 6 Hours
    Level 5: 1900 lumen 3 Hours
    Level 6: 2600 lumen 2 Hours
    Strobe: 2600 lumen 4 Hours
    I am going to test this one when it gets a bit darker here in Oslo! Can't wait........maby in 2-3 hours....
    Jul 2009
    Illinois
    You have one on hand that you can test?
    Oct 2012
    Oh goodness gracious, I just found my next thrower.
    Dec 2015
    Alabama
    Quote Originally Posted by Flashlightman.com View Post
    Max 2600 lumens
    IPX8 standart 2M.
    dont forget to post the pictures if you have them I'm very curious on how they turn out!
    ven's Avatar
    Oct 2013
    Manchester UK
    Very nice, wonder if they have sorted the charger issue out from previous models, even the revised carrier and charger are still not right............maybe got it right this time?
    Feb 2016
    Central Ohio
    wondering why it was 'discontinued' so quickly
    Oct 2012
    Quote Originally Posted by MrZelly View Post
    Vinh modded some of these and he sent out an email a few weeks ago that he had just finished the last batch because Acebeam had decided to just have the K70 as their thrower.
    Feb 2016
    Central Ohio
    Yeah, I did get one from Vinh, but still curious as to why such a short production from Acebeam.
