Malkoff
Results 1 to 3 of 3
Thread: New guy first question
    Default New guy first question
    A few months back I bought a traffic advisor light bar off Amazon. Low and behold some of my leds have burnt out/quit, not sure. My question is: how can I troubleshoot to make sure it's not just crappy construction?
    Moderator Alaric Darconville's Avatar
    Sep 2001
    Stillwater, America
    Default Re: New guy first question
    Welcome to the CandlePowerForums!
    Quote Originally Posted by Kkirwan71 View Post
    If you paid substantially less for it than you would have for a Whelen, Code 3, or Federal Signal product of the same function, you should know the answer already.
    Sep 2010
    Niagara Falls ON. Canada
    I design and build these for a living for a North American Company. Check the following before opening the TD:
    1. Ensure that the control box is functional...check all fuses, ensure each channel (if present) is functional (use a voltmeter).
    2. Check all your external wiring for bad connections or corrosion. A lot of imported TD's use aluminum wiring and it tends to fail.
    Now inside the TD:
    3. If it's modular and connected with a harness check the wiring on each module and the harness. If it still doesn't work that's it (modular ones suck for repair).
    4. If it's connected to a terminal block check for corrosion and check all the connections.
    If you still have LEDs out then the circuitboard has an issue and your screwed.
    Whelen & Federal Signal make pretty good TD's. I work for another company in Canada and we make excellent TD's and arrows, but I do not post to promote. If you want more information PM me.
