Kailoveoutdoor
Some one may have questions why do I pay more to buy an USB rechargeable flashlight? Below is what I am thinking;
1) Cost a lot less in the long term; Think about all the batteries you bought for traditional primary battery powered flashlight, though the lights are cheaper, the cost on batteries you paid before the light throughout its lifetime is much higher than you paid for a expensive rechargeable flashlight. Who doesn't want to save money, especially in the tough economic conditions?
2) More environment friendly; For traditional primary battery powered flashlight, when the battery ran out, a new one needed to supply power to the flashlight. What about the used and discarded batteries? If mishandled will cause environment damage. Yes, rechargeable flashlight also uses battery, but it is rechargeable battery and its circle life normally up to 300 to 500 times(ran out to fully charged is one circle). So in a way, it is more environment friendly.
3) Easy to keep charged; Thanks to a built-in(hidden) micro USB charging port, these kind of flashlights can be charged on any USB devices such as power banks, laptops and cars etc. as long as you have a standard USB cable(guys, don't tell me you do not have USB cables), meanwhile an extra charger is not necessary(save money as well).
4) More power and longer run time; One of the biggest issues that people have with traditional battery powered flashlights is that they're not able to run brighter for longer. Comparison to traditional primary battery, rechargeable li-ion batteries can offer more power to the flashlights and run longer. Even though you'll notice the lights starting to dim as the power gets less and less on a rechargeable flashlight, you don't see the significant difference until you've been using the light for a long while. On top of that, you can recharge it when you start to see it go down in brightness – you don't have that convenience when you're using a traditional battery powered flashlight.
Hope above helps you out.
