New Mag C-cell incandescent twisties: ML25IT
StudFreeman
Maine
Looks like Mag adapted their new ML25LT to incandescent. It's a slimmer design, probably coat-pocketable.
ZBattery has 'em. Ostensibly it operates like a beefed up MiniMag. Kinda neat! 2x26500 with a 5-cell lamp would be pretty nice :cool:
Whoops: typo in thread title. Should be ML25IT
apete2
Re: New Mag C-cell incandescent twisties: M25IT
Good to see incans are still alive. I have started building Mags again recently, with the new lithium batteries, we don't need AA adapters any more. I will order a 3C soon and see if it will fit 26650s and report back.
I have been using a 2D with 26650s and I think the 3C will fit it a coat pocket better.
swampgator
Gatorville, Florida
So the ML is now available in both incan and LED???
Sp@rky
It's not on the website yet in true Mag fashion but it's in the product catalogue.
Not sure I can post the link so if you search
MAGLITE_CATALOG_1215B.pdf
fivemega
California
Very similar but enlarged to fit pair of 26500 cells, built in G4 ceramic socket, 10 Amp tail switch and M*g C head.
2C001.jpg~original
Greenbean
WNC
Lets see what the inner diameter is going to be,
Here you go...
Conte
Hmm, 26650's were too tight to fit on a mag C before.
But two 18650's in a 2C mag is a classic mod that still works great today.
Greenbean
WNC
2C,
You remove the spring in the tail cap and remove the anodizing in it and the second cell sits in the cap actually.
Put some copper tape around a piece of foam down in the tail. Thing is I had to use unprotected li-ion blue top Sanyos to fit.
bykfixer
Dust in the Wind
So...which came first...the chicken or the egg?
As in the "IT" or "LT" version?
As of yesterday the web site did not show any C size incans.
Yet the catalog shows all the popular ones (thankfully)
Even the incan solitaire...
ZMZ67
Colorado
Received my M25ITs yesterday.The IT uses a bi-pin bulb like the other newer Mag incans.The stock 2 cell bulb isn't all that great,I have too many LED lights too be impressed at all by the standard bulb. I will probably look into the 5-cell bi-pin bulb driven by 3XCR123 just for fun.
bykfixer
Dust in the Wind
I figured out that if you unscrew the bezel a few turns with the light head in off mode until the light turns on...then switch it on/off by the tail cap, beam improves greatly.
It's a 2 cell mag star like what comes in 2C/D lights and it protrudes way too far.
By unscrewing the bezel it allows the reflector to move forward about a milimeter making the spot wider and that filament shadow you see on the wall all but disappears.
Next I'm going to give it a light orange peel with krylon high temp clear coat.
Mag coulda/shoulda done better imo. But I still like the platform.
Like you said a 3x123 with a 5 cell bulb should be sweeeeeeet!
Timothybil
The great state of Misery (Missouri)
Just to keep the record straight, a true C size cell is 25550. So two 18500 cells with a 100mm spacer (preferably copper and suitably shrink wrapped or insulated) would be ideal.
I have never been a fan of the method by which Mag does their so-called 'flood' beam. It is really just a spot beam unfocused to allow the light rays to bounce all over the place instead of staying together in a spot beam. In an incandescent, to created an unholy amount of artifacts. I haven't personally seen an LED Mag, so don't know if that is any better.
scout24
Penn's Woods
It wasn't me! It was Fivemega!!! (Beamshots, please, by the way...) :)
bykfixer
Dust in the Wind
^^ coming up.
I've got some TL3 bulbs on order along with some 'good' 18500's. But a trip to batteries plus bulbs yielded some 'solar light' 1000 maH batteries and I have a few 4C mag xenons in stock.
2 cell bulb was an insta flash with the 18500's. But the 4 cell bulb has a few minutes on it and so far so good.
Brb...
I'm back.
First a couple of photos from the light in stock form.
^^ yuck!!
That was the best beam I could muster.
^^ eh, not so bad for a measely 30 lumens.
But thanks to a tip from fivemega and a nudge from scout there is better.
^^ big dif
^^ even better
^^ good ole Mag hole begins
^^ double heck yeah!!!!
The garage in the distance is about a football field away.
^^ let there be throw... ala incan.
The neighbor several doors down shaded his eyes going 'oh no not again'...
So as you can see there is a huge difference. Not only is it a lot brighter but the quality of the beam went from junk to not bad at all. And now instead of picking the least ugly spot, it can go from a pencil spot to one about 3x wider before the black hole sets in, and become a decent flooder before the rings of saturn set in.
Edit:
The supplied lens gets mighty warm mighty quick. So I emailed flashlight lens .com to see if they will be selling replacement 40mm's and to see if glass will be available.
So in other words my little $15.99 + s&h + batteries flash light is up to about $60...so far.
ZMZ67
Colorado
Why not 2 protected 18500 with TL-3 bulb for brighter beam and free lumens?
Not a big fan of rechargables outside of eneloops but I might be willing to give it a try on this light.I like the small 2C platform just not sure how much I will use an incan these days with so much available on the LED side now.
