- Joined
- Aug 28, 2012
- Messages
- 351
I've tried to search, but I can't seem to find exactly the info I need. I'm building a pretty standard LE...I have a copper heatsink, I have a pretty standard triple LED on MCPCB and a pretty standard driver. I want to be able to remove the electronics and re-use the heatsink if I ever decide to upgrade. At that point, I'm not so much concerned about the parts being destroyed in the process, however, I'd prefer that not to happen if possible and to be able to remove the LED and driver without too much drama. But I certainly don't want them to fall off the heatsink either.
So, having said all that...what would you use to mount the LED and driver to the heatsink? And would you use the same thing for both LED board and driver board? Any recommendations on compounds?
Thanks very much!
Thanks very much!
