TheBelgian
New edition of the TK09
Launch debate over if this is a true/good "tactical" interface
So... no grip ring? Or can you still put one on it?
I'd say that's exactly how it works - if it's you'd have to switch it off and on again within one second to cycle to the Mid level. I can't say it for sure as I don't have the light but I don't see how it could work differently if the on-off-on within one second changes modes.I'm also a little confused on how the mode changing works. If you turn it on it's on high/turbo, right? But then if you don't press anything within 1 second is it "permanently" on high until you fully click if off after that one second or can you still cycle the levels by tapping after it's on all the way?
I'd personally like it where if it's on all the way and in turbo you can't change it until you turn it off. That seems more "tactical" if you will in that then you can't accidentally bump the button and change the modes while on.
Does somebody know how it works for sure? Does it work like the original TK09 mode changing?
