erict18650
Just picked up a Nitecore MT40GT and wonder if there are any precautions one should take when running two cells in series? I'm using Nitecore 3400.
Thank you for the info. I don't have enough sells for all my lights but have two brand new cells I use between my two single cell lights. I wanted to also use those two cells for the MT40GT light. If I charge them both up before using them in the MT is this ok?
Just to add to all the good info above-
Ideally you would start with two new cells but in this case it sounds like both your [not very old] protected nitecore 3400 cells are the same age so , the most important thing as already stated above is you measure [ multimeter required] the starting voltage and the finishing voltage, ie say they both start of at 4.18 volts, you run the light down to say 3.6v and check that they are even or with in .03 volts say 3.61v and 3.64v you will be fine. Keep measuring and check for start and finish voltage deviation for the first couple of charges [ i measure every time ]
Because your cells are protected they will trip to zero volts if they are using to much current. For more info read up on cells in series and dangers of reverse charging,
Although not ideal, you can use them.
