After researching single cell AA lights that can run on all battery types I've narrowed my choices to the Fenix LD09 and Nitecore MT10A. I also came across the Nitecore SRT3 (which can use AA or CR123) and these lights started me thinking. Will functionality be negatively affected by the broad range of chemistries, input voltages or battery sizes?
I'm not referring to lumen output. It's an expected and accepted tradeoff to have reduced brightness (between alkaline and 14500) in exchange for an emergency light that can use whatever is available at the time. I also accept that "do-all" lights are a series of compromises in beam quality, run time, UI, output, etc.
I'm more curious to know if the basic functionality/UI will be affected. For example I'd be ok with a strobe intensity that decreases from 200 lumens to 100 when switching from 14500 to alkaline but are there instances in which features are completely disabled? That is to say, strobe works with 14500 but not at all with alkaline?
Are there other things to consider?
Dan
Dan
