I think either one or both of the following changes to the ZL UI would be great:
- 3 modes per main level instead of only 2.
- make all the modes in each main level programmable instead of just the lower one.
Any arguments against these?
I've often thought that both outputs for each level should be programmable, so I'd be on board with that. I don't think I'd like having additional modes per level though. Quick access to 6 levels is really quite enough for my usage. But I wouldn't swear off of Zebralight forever if they did it.
I don't like the idea of a "fast single click" taking you up a level, however. That means turning the light off just became a long press and that's annoying. I don't like that. The Manker U11 I just bought works like that and its not better than what Zebralight has.
I suggest they also add that a fast single click from low or medium takes you up a level so you dont always have to hold and scroll through low when your in medium for instance and want to get to high.
^^Just hold the switch down from off until M comes on. About a second. It is designed so that low, medium or high can all be reached with one click.
How would you turn it off?
If I understand you correctly... This gets messy and becomes too much to mentally keep track of.I think either one or both of the following changes to the ZL UI would be great:
Turn the light off, pause, single click. It's faster than cycling.Right, I never thought about that. I just find it really annoying to have to scroll through low to get to high. There must be a better way. Ideas?
Are the 3 modes per main level programmable? If so, how many options do they get? 2? 3? That would result in 18 or 27 options per main level (+1 for the default level)! Total, that's 57 or 84 brightness levels from which to choose per light. And how would one easily click their way into the programming of these modes, with all the clicking that's taking place just to get to these modes? It's a cumbersome obstacle to address in my book, let alone explain to the user. (One that has this specific of lighting level needs would benefit from a rotary/infinite output adjustment flashlight instead.)
So then suppose the 3 modes per main level are not programmable in this scenario. You just double click through M1, M2, M3... Would you still want to program the default M level? (I'm now referring to your second bullet point.) I think one needs that constant, unchanging default. It does 2 things: It sets a frame of reference where low, medium, and high are. And it prevents much confusion to the programming of the light, which for some, is already a little tricky. Without that constant, you no longer have sub-levels. You just have 2 arbitrary sets of medium levels. You have brighter mediums, and dimmer mediums. Brighter lows and dimmer lows. And so on. And like before, and added layer of complexity is required for the user to configure this setting.
These 2 suggestions radically alter the existing acclaimed UI Zebralight is known for. I'm not too keen on that as a Zebralight fanboi.
I hope this make sense, I'd feel better if we were discussing this in front of a white board!
The only major change I can see of any real benefit would be to allow the programming of H1 level to any of the H levels.
I like the max output but for practical purposes I think being able to program your H1 setting for more conservative battery use (ZL's strong point IMO) but still giving that extra punch over the lower H2 level would be a really big thing for most people..
Sure, two modes, low and high, forward clicky with momentary on.
