Prometheus
Results 1 to 7 of 7
Thread: Trying to build Small sbr-90 Light need help
    Default Trying to build Small sbr-90 Light need help
    Hey Guys I have bitton off more than I can chew and need help. I'm trying to build a small pocket flashlight out of an SBR-90 but am a little lost.
    I want the light to be all through so I know I need an aspherical lens style light which is awesome because I have tons.
    What I don't know is do I need a reflector for a dome-less LED.
    I plan to only run the led at 3 amps as I found on my bench PSU test to be plenty bright.
    Im looking at hosts like this but IDK of i can get away with.
    https://www.fasttech.com/products/1618/10002463/1277401
    this is what I'm going for but brighter.
    http://the-gadgeteer.com/2012/08/01/...hlight-review/
    Any help or advice would be greatly appreciated.
    Flashaholic* BLUE LED's Avatar
    Apr 2008
    UK
    Default Re: Trying to build Small sbr-90 Light need help
    You are going to need a lot of help. I would suggest asking in the home made and modified section.
    Your set-up seems a little odd to me in terms of your choice of LED and host.
    *Flashaholic* Str8stroke's Avatar
    Nov 2013
    On The Black Pearl
    BLUE is right.
    What is your goal? Intended use and run time?
    3 amps is pretty strong and you are gonna need a heat dissipation plan.
    That host could work, but you have to consider your goals, heat dissipation, driver, battery, then lens and reflectors. That COB led is not really optimum for a throw led.
    Welcome to CPF. Did you search BLF and see if anyone has messed with that led?
    Interested in Saltytri lights. Pm me!
    Thanks guys Run-time should not be an Issue as I have a nice copper puck for it. I already tested it at 3 amps for 5 minutes and it does not get too hot.
    I have a camera with an electronic viewfinder and this light is mainly so I can light up the woods across the street to focus my camera. Run time could be 8 seconds and I would not care.
    Ive searched for others with this LED but can only find Pre built reviews.
    My main issue is I just need to know the best way to drive this LED I'm not to familiar with drivers.
    Edit: been looking around but cant find any.
    Anyone have any good links that explain throw vs flood light.
    Apr 2008
    UK
    Are you after a thrower in a small light?
    Don't forget to use thicker bond wires and a good 18650. That is if you are going for the single 18650 route. Do you know what voltage range you are after.
    OK sorry for the delay been busy the past few days.
    It looks like I will need a large mag-light style host.
    that being said I may do a Jayrob style build or buy a used Olight SR95S-UT
    Apr 2008
    UK
    This makes much more sense now. Using a larger light with a bigger reflector will it throw I have not used the SBR-90 LED and I am not sure how easy it is to focus. Based upon that it would be better to use a Mag host, as there are different reflectors available.
    This might be a better option to buying a used Olight SR95S-UT; because this is already a thrower and the SBR-90 may or may not focus well.
    It sounds like an interesting project which ever you decide.
