The discharge curve on Turbo mode shows that the output is highly depending on the voltage.
With decreasing the battery voltage,the brightness becomes lower.
The brightness is still impressive for a compact flashlight,but without a specific buck-boost driver,the output is performing as direct drive.
There is a difference in the performance on both tested samples.Yes,no flat regulation as many may expect,but for a 6V LED and no boost circuit,the result is normal.
The higher output is mostly a result of the different LED.The cool white LEDs usually show higher lumen output.
A small cooling fan was used to get the optimal performance.
No timed or thermal step down in my test.
A closer look at the first 60 minutes.
Here is a more interesting graph,comparing the High mode on the EC4S and Turbo on the EC4.
This is a comparison of the EC4 on its max mode,and the EC4S on High mode.
Lower output,longer run time.
Lumen measurements:
30 sec after activating.
Turbo mode
1990 Lm (2080 Lm initial) (the max output highly depends on the batteries)
High mode
934 Lm
Mid mode
392 Lm
Low mode
61 Lm
UltraLow mode
1 Lm
Pretty well spaced brightness levels.
Because of the electronically working dual side switch,the flashlight is in Standby mode,while the light is OFF.
In this state the driver consumes small current from the batteries.
My measurements show: 350µA on the prototype and
180µA
on the latest tested version.
This will not be a problem if you use the flashlight every day,every week,but if you plan to keep it on the shelf without using it for weeks,or months,it is recommended to take out the batteries,to prevent unnecessary discharge.
It is definitely not a good choice for emergency flashlight that will stay without use,in case you need it someday.
Both EC4S samples I tested seems to have slightly different driver electronics,not only because of the lower Standby consumption,but also because of the way of controlling the brightness.
There is something like a PWM controlling on Low and Medium modes in the EC4 and EC4S NW. I don't detect any similar flickering in the Cool white EC4S sample.
