Hi Guys,
Looking to build a modded Maglite. Intent is for a high output light for doing short-duration searching in thick grass so battery life not a major factor and doesn't need to be too small.
I have a XM-L T6 3-LED 5-Mode 1800LM reflector (http://www.dx.com/p/xm-l-t6-3-led-5...op-in-led-module-w-temperature-control-114013) , a stack of 3/4/5 D cell Maglite bodies, a bunch of 26650 5000mAh cells + a lathe.
I'm a bit confused by this reflector: the DX website pretty explicitly states that is does 5 modes and has a digital regulator but there is nothing in the packaging to show how this works and no external connectors except the spring terminals on the unit.
Does this actually have a driver circuit in it? Not at all obvious from an external inspection though the description is pretty specific. If so, any idea what type of switch I should use with it? Can I use the stock maglite switch or does it need to be modded as per http://www.candlepowerforums.com/vb...mod-(8-brightness-levels)&p=618553#post618553
Thanks guys...
Thanks guys...
