Hi guys I left my 2.5 version(non pro) in an industrial freezer room at work for over an hour inadvertently, which probably brought it down to 5 or 10 degrees. Upon recovering it later that night the output was very low. However I re-charged the battery the next day and it was a lot better, but I don't think its getting to full intensity anymore. Also when I click it on at full power it seems to drop back to just slightly lower output about 1/4 second later, only a slight drop in intensity though. Not sure if it was doing this before, does this sound normal?
Could I have damaged the battery by freezing it, or even the flashlight electronics itself?? Both battery and torch are only month or so old. Maybe I should buy a new battery and see if it makes a difference... Thanks for any suggestions.
