2 of them are about 1/4 of a city block, 3 are parking garages 3-4 levels, and then there are some residential streets we check for Overnight parking permits. I was originally looking for multimodes with memory of pervious mode but it is not Important.
I live in the city with all it's charm and streetlights.
Being that there a very few dark spots other than shadows cast by trees and items like cars and buildings the Streamlight Stinger LED should work well in all that 'free' lux of the typical city. It will brighten all those dimly lit places effectively for a few hundred feet while providing a good couple of hours of runtime on high.
I've had mine since Christmas and it's only been recharged once...not because it was dead but a couple of weeks ago we faced a potential lights out a few days scenario.
The light provides a high beam each time you turn it on. Once on you hold the switch to cycle high, med, low, med, high. Low is 65 lumens.
The beam is a bright white, fairly narrow spot with a ton of spill.
In complete darkness it effectively lights dark objects the length of a football field in the rain.
I'd suggest if you get one, get a pocket sized light like the Streamlight Microstream or Protac 1aaa to use 90% of the time.
I wanted to suggest a Strion LED. It has the same UI as the Stinger LED but a lot less runtime due to the smaller sized battery. If you go that route opt for a piggy back charger and an extra battery.
Your nearby Batteries Plus bulbs will likely have a Stinger in stock for you to hold in your hand to see if it suits you. They'll also likely have a microstream along with a bunch of cool Nebos to pick from.
Nebo doesn't get talked about much here but they make some mighty fine flashlights.
