Here is a compact light that runs off of super capacitors. Since there are no batteries you need not worry about corroded alkalines or Li-Ions that have drained to low and can't be used (or take a long time to charge). It is always ready, roughly every second of cranking gives a minute of light. Max run time on this one is 1/2 hour but since it charges again so fast it is no big deal. It isn't going to win any brightness contests with the 3 Cree 5mm LEDs but that is the tradeoff and it is completely functional. The crank-LED electronics inside are from the "Laserhacker" website. I just designed the casing and had it 3D printed. It is much better than those shaker "Jag-lights".
