HDS Systems
Page 4 of 9 FirstFirst 123456789 LastLast
Results 91 to 120 of 245
Thread: **Team CandlePowerForums** for SETI@home !
  1. #91
    Flashaholic* psychbeat's Avatar
    Nov 2009
    SF norcal
    Default Re: Announcing **Team CandlePowerForums** for SETI@home !
    Hahah rad.
    I've left my laptop running boinc all weekend - drop in the bucket
  2. #92
    Sep 2010
    North Carolina
  3. #93
    Quote Originally Posted by psychbeat View Post
    Hahah rad.
    They all add up!!
  4. #94
    We are now three slots AHEAD of Microsoft!!
  5. #95
    Moderator Alaric Darconville's Avatar
    Sep 2001
    Stillwater, America
    I'm going to have to scale back on my core/GPU usage and the CPU time percentage once air conditioning season hits. Right now, my utilities are low enough to allow use of my system to really crunch, but it won't stay affordable for long!
  6. #96
    Administrator Kestrel's Avatar
    Oct 2007
    Willamette Valley, OR
    Ya I was thinking the same thing - no problem running S@H to augment interior heating during the colder months; however, running more AC to get rid of that heat is a different animal. Although I only run laptops, I'm really impressed with how hot the air is coming from each vent, and these laptop fans are running at a 100% duty cycle - when I turn off S@H the laptop fans turn completely off (not just down) almost immediately.
    No AC here, but a similar concern re: indoor heat. I will probably leave my faster laptop up, but will power down my ancient Dell when I'm not using it - fewer workunits accomplished per kWh (& waste heat) for sure.
    #164 for output - great job folks - but I think things have been leveling off already with regards to standings.
    Team Microsoft was left in the dust (10 slots behind us now), but no really noteworthy teams are just above us with the exception of a few prominent universities etc.
    (Penn State @ #161 I'm thinking)
    With regards to total team credits, we're at ~93% now and I do expect this to climb for quite some time however:
    Quote Originally Posted by Kestrel View Post
    Historical info: (team ranking - total credits)
    Day 001 (Feb 23): 16th percentile
    Day 002 (Feb 24): 26th percentile (+10)
    Day 004 (Feb 26): 34th percentile (+8)
    Day 008 (Mar 01): 41st percentile (+7)
    Day 016 (Mar 09): 54th percentile (+13)
    Day 032 (Mar 25): 82nd percentile (+28)
    Day 064 (Apr 26): 92nd percentile (+10)
    Day 128 (Jun 29):
  7. #97
    It's impressive for a little team like ours. I've added in my home desktop, but that doesn't run all the time. Every bit helps!
    Have torch, will travel.
  8. #98
    And Nitroz gets the gold badge!
  9. #99
    Sep 2010
    North Carolina
    Quote Originally Posted by millguy View Post
    I just saw that! Congratulations Nitroz!!
  10. #100
    Oct 2007
    Default Re: **Team CandlePowerForums** for SETI@home !
    Good job Nitroz.
    Looks like things have settled down @ #160 plus/minus, with Team IBM and the entire Christian religion only a few slots above us.
  11. #101
    Nov 2009
    SF norcal
    Good times !
    I'll try n leave my little laptop running this weekend if possible.
  12. #102
    Sep 2010
    North Carolina
    I took a vacation last week. Stayed at home and used some of the money usually spent on going places to build a medium gaming (seti cruncher) computer. At least that's what I told the wife, even though I don't really play games. When I come home from the stress of work, gaming doesn't relax me all that much so I never picked it up. It's based on a Dell precision T3400 I got at goodwill for 10$. If anybody's interested I'll try to remember to post what changes I made to it and how its doing for speed and heat management along with the total price. I think about $300 all in but could be less.
  13. #103
    Sep 2010
    North Carolina
    Just a quick follow up to the system I built up last week. Dell T3400 core2 duo (2 core) 266ghz shell, no hard drive memory or video card. $10 I installed a core 2 quad ( 4 cores) 283ghz $20 to my door, 6 gigs memory $52 and a msi R7 370 video card $150. The video card was one area where I knew I went overboard but I was trying to future proof, in case I wanted to do this again with an updated system. You could easy spend under a $100 and it would do just fine. I already had a hard drive laying around so no cost. Win 7 install $25 free upgrade to 10 was installed. At this point I was done. Total $257. Average time spent for a work unit on the cpu 2.5 to 3 hours X 4. The gpu takes about 18 to 20 mins. Heat, 158F across the cores at full load. To hot, so I removed the side panel that reduced it by 10F, still to hot for 24/7 running. I did some research and found Dell made 3 heat sinks for this model, alum which is what i had and copper for the others. I found a copper for $13 and now it's running 118F across the cores with the side panel on. Total $270. I also installed a 500 watt power supply $50 even though the 375 watt original was working fine I became concerned about the video card under voting so I'm not adding the price to the total. This build was a lot of fun and for me well worth what I spent. It's been over ten years since I've put together a pc system, I'm a Apple guy. I know some will scoff at money wasted but I'll have months of fun tweaking and playing with it along with running seti.
  14. #104
    Nov 2009
    SF norcal
    Quote Originally Posted by whill44 View Post
    Not a waste at all!! It's all "personal research" and much more rewarding than a few expensive dinners
    I do the same with tubes speakers & components in my guitar amps.
  15. #105
    Flashaholic* Nitroz's Avatar
    Jul 2004
    Monroe
    Awesome!
  16. #106
    Sep 2010
    North Carolina
    I'd like to make one last post about the Dell T3400 I'm using. I checked power consumption with my UPS and it's reading 202 Watts under full load. That's not free running by any means, but not as bad as it could have been. Like some others have stated summers coming and I'm in the process of clearing seti work units off computers that might suffer from the heat. I intend to keep this one system running through the summer months, hopefully that will be enough.
  17. #107
    Nov 2009
    SF norcal
    Yah - I had to throttle down my laptop as its my only computer and I use it for my music recording.
    I have it on 90%cpu now and the fan doesn't have to run so high
  18. #108
    Sep 2010
    North Carolina
    That was probably a good idea. Seti pushes a computer pretty hard, the heat builds up quick and stays high. My windows laptop fan ran on high the whole time.
  19. #109
    Oct 2007
    Now that the hot weather is here (100F last Saturday), I've throttled down my 'faster' laptop by 50% and my Android by a little.
    Team CPF has certainly dropped back a bit in the 'avg daily output' ranking but we're up to the 95% percentile for total credits at least.
  20. #110
    Nov 2009
    SF norcal
    Hope to run mine a bit this week - been too busy at the studio and my laptop is already maxed out running protools
    I'm house sitting and can leave it going all night. I still get a kick outta earning a few credits here n there hhaha
  21. #111
    Sep 2010
    North Carolina
    A battle for position is under way. In the right corner sits the long time 2nd place holder Nitroz!!! With his ample supply of quad core computers and what can only be assumed as a cooler AC unit, comes out crunching. There's a reason why he's number 2 boys, he can bring the heat and stay cool doing it. In the left corner the challenger a scrappy fellow kinda sweaty but determined to cause a ruckus whill44!!! As it goes back and forth between the competitors who will come out on top. Stay Tuned.
  22. #112
    How about whill44 and Nitroz combine resources and go for Millguy. Geeeezzzz!! Look at his credits!
  23. #113
    Sep 2010
    North Carolina
    Quote Originally Posted by badtziscool View Post
    I can't speak for Nitroz but thinking of what it would take to catch up to Millguy is like trying to stare into the sun, it's just to painful.
  24. #114
    Oct 2007
    An interesting current-events discussion thread over at the S@H forums:
    Arecibo still threatened with closure
  25. #115
    Oct 2007
    Hmm, after the BOINC Android update last ~Friday my phone stopped getting new workunits, would only complete & return what workunits it had. Would just refuse to get new workunits. Tried restarting, also removed & reinstalled the client twice, now I can't even get the software to connect to my account. Looks like I'm more than 50% down for output ...
  26. #116
    Oct 2007
    BTW, if anybody is running this on their Android, you might want to avoid the latest BOINC update (& turn off auto-update for that specific app as well).
    I checked the S@H forums and it looks like on some devices, the new version is mistakenly looking for only 64-bit workunits (which aren't available) instead of the existing 32-bit workunits.
    (Am certainly not an expert, just relaying what I've read there.)
    I've removed the latest version on my Android and am happily running again with v7.4.43. Just a FYI,
  27. #117
    Nov 2009
    SF norcal
    I'll upload a few units next time I can get my laptop to Internet I'm still rolling but it's hella slow going for me.
  28. #118
    whill44 is on the move!!
  29. #119
    Oct 2007
    Haven't been keeping up with this lately (does my sigline pic even display correctly anymore? ), but still chipping away w/ a ~25% reduction in output.
  30. #120
    Sep 2010
    North Carolina
    Thanks, I wasn't sure you could run a amd and nividia card together in the same computer, turns out you can. Who knew! I'd like to report a sighting of millguy in the distance, just an outline Mmmmmm, might be a bush.
