Sunwayman P25C, Streamlight Polytac, Jetbeam, OTHER for Arson Machine Co. 1" Ring ?
Hi all,
BEFORE I pull the Trigger.....I am seeking advise/help/suggestions from the good members of CP Forums. Here's the deal. I have been perusing the Net for the last several days attempting to find a "BUDGET" (UNDER $50.00) LED Flashlight (with surprising little success) that has a ONE INCH diameter body/tube to fit into a ARSON MACHINE CO. 1" RING to attach to Carbine. I seek a "simple" REAR CLICKY Flashlight that has (at minimum) both a HIGH and LOW mode. I no doubt will have to use CR123 size Cells (either one or two cells) to fit that ONE INCH diameter Ring. Thus far, I have only been able to come up with three BUDGET lights that appear to fit the bill. The SUNWAYMAN P25C, the JETBEAM WL-S2 and (the least expensive) STREAMLIGHT POLYTAC. If anyone has any other suggestions (with the aforementioned needs) I would be greatly appreciate and welcome your suggestions. Thank you.
ONE INCH DIAMETER
$50.00 or less
REAR CLICKY
HIGH & LOW
ONE or TWO CELL CR-123
EXTRA Side switch OK but MUST be Rear Clicky
Regards,
SixCats!
Hi all,
ONE INCH DIAMETER
$50.00 or less
REAR CLICKY
HIGH & LOW
Regards,
SixCats!
