Mar 11, 2016 #1 E eh4 Flashlight Enthusiast Joined Oct 18, 2011 Messages 1,999 Is there any such thing? 10-15mAh would be fine.
Mar 11, 2016 #2 HKJ Flashaholic Joined Mar 26, 2008 Messages 9,715 Location Copenhagen, Denmark There is a 10180 cell, it is fairly common. It is ø10mm and length 18mm with about 70mAh
Mar 11, 2016 #3 C CuriousOne Enlightened Joined Oct 14, 2012 Messages 813 They can be found in cheap e-cigs, but they are mostly LiPo. If coin cell shape is OK, than there's much larger choice.
Mar 11, 2016 #4 Tre_Asay Enlightened Joined Jun 12, 2015 Messages 398 Location Caldwell Idaho If you can find a panasonic CG-320, it is 3mm x 20mm and claims 13mAh. The problem is that I don't think panasonic has actually produced any to be sold.
Mar 12, 2016 #6 M m4a1usr Enlightened Joined May 4, 2013 Messages 884 Location Washington State The GP0820L07 fits your dimension requirements almost perfectly. 8.2mm diameter and 19.5mm long. 3.7 volts but it's 60mah. Lithium Ion rechargeable . Last edited: Mar 12, 2016
Mar 12, 2016 #7 E eh4 Flashlight Enthusiast Joined Oct 18, 2011 Messages 1,999 m4a1usr said: The GP0820L07 fits your dimension requirements almost perfectly. 8.2mm diameter and 19.5mm long. 3.7 volts but it's 60mah. Lithium Ion rechargeable . Click to expand... That's almost too good, thanks!
