[ QUOTE ]
paulr said:
Re night vision, about 2 seconds of Google searching finds this:
[/ QUOTE ]
yes, I have done extensive searching on "night vision", and if you recall, took part in many discussions in CPF.
Ref:
Human Night Vision Preservation
Preserving Night Vision - Colors?
Indeed I have also read about the eye being most sensitive to green in daylight and switching to blue/green for twilight/darker conditions.
However having the eye being most sensitive to blue/green in darker conditions does not necessarily make the light better for seeing
clearly by -
and I will make it explicit - to see clearly with reasonably good contrast and definition - and not vague outlines of large object, where I would be extremely uncomfortable and feel unsafe.
(that is afterall why I carry a flashlight in the first place).
As I tried to make it clear that my so-called "dark adaption" is most probably
not true "scotopic" night vision, and I also very much doubt anyone's "night vision" is scotopic under normal urban conditions - simply due to the amount of light pollution.
I cannot explain why I see better, clearer, more contrast and definition by yellow than almost any other color.
I can only make subjective surmises/guesses at perhaps at a combination of apparent increase in contrast and possibly less bounce-back glare - whereas green, blue/green and especially blue seems to be glaring, and adversely affects my dark adaption recovery (I sometimes get after images when the lights are switched off - whereas with yellow I don't appear to be affected as much. Red might be as good - but I just don't seem to see details well at all under red light) I am sure if I reduce the intensity of the green, blue/green, or blue lights I would probably suffer less glare - but I am not sure if I would then be able to see details as well under the dimmer conditions - just like with Red - I am sure if I increase the intensity of the Red I would see better - but then the higher intensity would then probably glare more.
Sorry to have gone on so long - but I hope you can understand what I am trying to get at -
To me this is a subject of immense interest -
my own experiences points me to yellow LEDs -
but I also understand if it might just be my eyes,
and even personal bias.
Unfortunately, even though I have also found plenty on the net advocating one color over another -
I am just not that convinced of how authorative any of those references are......
(eg:
USAF Flight Surgeon's Guide: Chapter 8
(about 2/3 down the page under the heading "Night Vision")
Clearly states that red is the correct color to preserve human (scotopic) night vision -
Even so there still remains confusion over whether Red or Green is correct for night vision - to the point where green or blue/green are advocated over red, which, if you think about it, is exactly the diametric opposite to what the USAF surgeon's guide is recommending.)
