Hi,
I was thinking about buying the Pelican 2350 1AA light and wondered if anyone has tried using a 3.2V (LiFePO4) or 3.7V lithium rechargeable battery with it. If so, how much did the output increase? What was the runtime? Any problems with the user interface (UI)?
Pelican makes a 2AA model, the 2360, and I wonder if the 2350 uses the same electronics as the 2360. If so, a LiFePO4 battery should work and even the battery voltage indicator might then be active on the 2350.
