FNinjaP90
- Joined
- Jan 8, 2003
- Messages
- 888
I have a green laser but I don't really fancy the layout of the case. It's too long, and too skinny. It also doesn't have anything to prevent dust from getting on the final focusing lens. What I wanted to do was to stick the laser unit inside a 2x123A flashlight and use 2 5/8AA nimh cells to power the laser. They are slightly less same mah than the regular aaa cells that the laser uses. You might be wondering how I will push the button on the laser. The laser I have has a pushbutton endcap so when you supply energy to the pos and neg terminals, the laser will spark. The button is hard wired "on". The pictures below show how I can put the laser unit and batteries inside an e2e case.
http://www.geocities.com/hardcorebmw7/MVC-045S.JPG
http://www.geocities.com/hardcorebmw7/MVC-046S.JPG
The e2e case is great, and has enough clearance if I put in an o-ring spacer at the bottom of the bezel...but I don't want to destroy a $60 case. It would also be great if I can put some type of regulator chip inside that would keep the laser at 3V, up from the 2.4V of the batteries, but that would require a larger case. I've never actually dealt with one(I don't even know if it's possible to put one in), so I wouldn't really know the size. The laser is a tight fit for the e2e already, so the e2e case is out of the question.
So what flashlight would you guys suggest would be a good doner case that is moderately cheap? It needs exactly 3.5inches of clearance from the end of one battery to the tip of the laser unit, plus maybe a regulator unit. It doesn't matter if the front end of the light has a skinny hole for the lamp(light the e2e), I can always bore it out.
But then...I've been always thinking of getting an KL4...and a L4 would only be $140, a lot less than the what it would be to install a KL4 on the e2e PLUS getting another case for the laser. But it still isnt large enough to put an optional regulator case in, and still a bit too expensive. This would be a sweet project. Gimme some input guys!
