carnage
I just purchase a Fenix PD35 TAC light. Which battery should i use 18650 or cr123A, protected or not, and which brand?
Thanks for the reply! Can i use the same Orbtronic battery in the fenix hp12 headlamp, and what does the GA stand for? As far as the charger I don't own one. I was reading on the this forum that Xtar make a good one, any suggestion on any brand would be appreciated. My main concern with chargers is safety, not over charging, and reliable.Keeppower or Orbtronic 3500mah 10amp GA protected. CR123's have less than half the capacity of the GA 18650 but drive the light harder for roughly a minute or two before the cells buckle under voltage sag. The GA cell has very low internal resistance and at max output doesnt even break a sweat with very little or no voltage sag. The GA cell has stellar capacity for an 18650 its 10amp capability feeds the light as much as it needs also without breaking a sweat. The TAC gets pretty hot run at max for extended periods so a protected cell is just safer even though the light is very well regulated. The Keeppower and Orbtronic 3500mah GA cells are roughly $13-$15 each depending on where you get them. There currently is no better cell for the TAC available that I am aware of. You will get the max performance the light is capable of with this cell. Of course the TAC has timed regulation it steps down regardless of power source or how hot the light is or is not. Just turn the light off and on again and you will be back to turbo. Dont skimp on the charger. Do you have a good charger?
Thanks for the reply! Is there a certain model I should look at?As CC said, 18650 all the way!Xtar make excellent chargers, lots of variety to suit budget,if no plans on using more cells,single or dual bay...............think ahead and if more planned(more than likely if on here) then maybe a 4 bay charger would be better long term imo
They are also pretty accurate. VP2 will be the cheapest the VC chargers can cost twice as much depending on where you get them from.
You keep on mentioning GA cell, what does GA stand for? Newbie here.Surefire CR123's indeed come out of the same factory as the 1550mah Panasonic and Duracell CR123's and indeed are well made but lower capacity. Still 5 or 6 bucks for two at Lowes is a pretty good deal. CR123's will indeed drive the TAC harder than a GA cell for about a minute maybe two then they buckle under voltage sag dropping output. They made my TAC get very hot much faster than the GA I have in it now. I always thought the VP2 was cheaper than a VC2? Interesting...
Thanks for the explanation!GA is just their alphabetic end to the Sony core cell designation NCR18650GA which is the 3500mah 10amp unprotected cell most current 3500mah 10amp protected cells are based on. Just easier to say GA than NCR18650GA. Other examples are most protected 3400mah cells are based on the Panasonic NCR18650B cell. It is Panasonic/Sony's way of designating their 18650 cells. Other manufacturers are similar usually. Far as I know GA just means that...GA.
You never know.Gigantic Ar5e maybe:thinking:
