I'm looking for a dedicated thrower to compliment my headlamp for backpacking. I don't really need any spill from the flashlight, just MAXIMUM THROW. I prefer white light. A single 18650 would be preferable for size and weight. Upwards of 50k cd would be ideal, but i will compromise a little for form factor/sexy factor. I just want it to significantly kick my MH20 into the dirt as far as throw. Runtime is not vital because this will never be my only light. I am not a fan of tactical layouts and tail clickys but i could probably adapt. Customs/vihn's/tuners welcome. Any ideas?
50k cd is pretty easy in a smallish form factor.
But it really depends on if you really are MAX throw, as per your thread title. Or just good throw, vs physical size.
If you aren't wanting any spill beam, I would also say to look at lights that use a TIR or aspheric lens.
And a good question to ask is, are you into modding? If so, then it opens up a whole wrath of new options. Modding doesn't have to be complex. Indeed it might be as simple as unscrewing a few components and soldering two wires (really really easy).
For a reflector light, to get throw you want a large reflector. Generally the larger the better.
---this means good throwers are usually pretty big.
You also want a small LED in comparison to the reflector size
---An XP-G2 will out throw an XM-L2 or XP-L in the same reflector.
For the money this will probably out throw most of the "big" name lights, because many big name lights use the larger LEDs to get the headline lumen numbers.
http://intl-outdoor.com/xintd-c8-v5-xpg2-s4-multioption-18650-flashlight-p-789.html
The XinTD C8 is superb quality with a really good driver, and you get to choose which modes you want. It is also compact enough to fit in a pocket.
The reason it throws well, is the one I've linked to uses an XP-G2 LED and the C8 has a fairly large reflector.
If you went for a bigger torch still, then you can get more throw.
Now if you are into modding, then you have some options. C8's are very easy to mod and you can buy them as a quality host from companies like Convoy.
If you use an XP-L HI emitter, you'll get similar throw to the XP-G2, but with more lumens and a brighter spill beam. Or you could look at de-doming an emitter yourself. Nobody sells de-domed XP-G2 lights, but these will out throw any of the other LEDs pretty much.
For a more compact offering, you might want to look at some zoomy lights. An aspheric lens can be made to throw well too. The biggest advantage is you'll get no spill beam. The bigger the lens the better, just like reflectors. And the same LEDs will offer the best performance. Namely a well driven XP-G2, an XP-L HI (or a de-domed XM-L2 or XP-L) or best of all, a de-domed XP-G2.
These can make for lightweight compact throwers.
