ShineOnYouCrazyDiamond
Moddoolar/SureFire M3:
The following general rules apply for the M3 sale:
Looking to sell a great incan lego light. This light is made up of the following parts:
The light includes 2 MN-11 bulbs (one has a few hours runtime, the other is new). Also includes 4 x AW 18500 IMR cells purchased in Dec 2015. I am also including a small spacer which is required to make the batteries long enough to make solid contact on both ends in the battery tube.
Excellent HA match on all of the Moddoolar parts. The head is just a touch off but the match is still quite close.
Priced to sell at: $250 SOLD
Surefire E2e Triple:
The following general rules apply for the E2e sale:
I always wanted to make a triple E2e for the experience. This was my first attempt. The mod itself came out nicely but I did end up putting some marks on the body from the machine (see detail pictures below). The driver has a very nice dynamic range from a very low moonlight all the way up to ~5 Amps.
Here's what was done and what is included in the sale:
Important notes:
- The top interior of the battery tube was bored out a bit to allow the mod to fit into the battery tube. The head will not work with other E1e or E2e battery tubes unless they are modified.
- The bottom of the battery tube was sanded lightly to close the gap between the tailcap and battery tube when screwed on. This should not affect any functions if you decided to put the original internals back in the Z52. I thought it important to note since the work will be visible should you remove the tailcap.
- This light should only be used with one 16650 battery capable of 5 Amps, or one 16340 and a spacer. DO NOT use this setup with 2 x CR123 or 2 x RCR123/ IMR16340 cells as it will burn out the driver.
Price: $200 SOLD
Examples of some of the marks on the battery tube:
- Due to the batteries this is a US only sale.
- First posted "I'll take it." gets the item over any PMs in progress.
- Prompt payment via PayPal Purchase option appreciated.
- US Shipping included in price.
- Surefire M3 bezel (a few nicks on the crenelations as shown, but I did buy it used at a good price)
- Moddoolar DB TL100 HA battery tube
- Moddoolar C Tritted Triad Tail HA w/ clip (3 yellow trits installed in the slots)
- Moddoolar M Series Interface HA
- AW SoftStart switch in tailcap.
- Due to shipping restrictions battery will only be included in US sales.
- US and International shipping included in price.
- Surefire E2e with Z52 tailcap. (No box or other materials included)
- McClicky installed in tailcap. Will include the original internals of the Z52.
- SOYCD triple mod:
- XP-L HI U5-4000K neutral white mounted on Noctigon Triple mPCB.
- Dr. Jones H17F lucidrv2 7135/FET based driver. Excellent programmable features and a very low-low setting. (I don't want to hotlink so go to Mtn Electronics and search for lucidrv2 to see more details)
- Large Cu heatsink for excellent heat management. I've run this on full power (~4.5 - 5 Amps) for 5+ minutes and the light was hot but not burning.
- Bezel ring is removable so Carclo triple optics can be swapped. Clear narrow triple optic included with light.
- Triple assembly is permanently glued into position.
- One Sanyo/Panasonic 16650 2500mAh 4.35v battery included (US sales only). Battery can be charged to 4.2v or 4.35v depending on the charger you have without worry. Driver runs fine at either level.
Important notes:
Price: $200 SOLD
