Klarus
Page 2 of 3 FirstFirst 123 LastLast
Results 31 to 60 of 63
Thread: Nitecore MH20GT: XP-L HI V3,micro-usb, 1x18650, 362 meters, 1000 lumens, (beam)shots
  1. #31
    Default Re: Nitecore MH20GT: XP-L HI V3,micro-usb, 1x18650, 362 meters, 1000 lumens, (beam)sh
    Hi j75,
    If i compare my hotspot with the one you show in the thread opening mine looks much less well defined but I noticed that the led is about 0.5 to 1 mm out of center. In normal use i guess it is not a problem (or maybe i don't know what I am missing). I bought my GT at ledscherp.nl. I already have send an Olight SR52UT back recently since with that light there was also something wrong since it only out throwed my EA41 2015 edition with only 50 - 75 meters. Maybe they are getting not the best samples from flashlight companies ?
    What is the distance between the GT and the wall of the picture with the hotspot comparison in the opening of this thread ?
    Quote Originally Posted by kj75 View Post
    I've added some new comparison shots to the review, that show the difference between the MH20 and MH20GT:
    Here they are again:
  2. #32
    Quote Originally Posted by pblanch View Post
    Gotta admit I can't figure out the self testing voltage levels (flashes after you screw on the cap)
    Couldn't be easier. 2 sets of flashes. First set 1 flash per volt. Second set 1 flash per.1 volt. So 4 flashes slight pause 2 flashes = 4.2 volts!
  3. #33
    Flashaholic* kj75's Avatar
    Sep 2012
    The Netherlands
    Especially a thrower needs a well-centered led. A you have to be a content customer. Ask the dealer to exchange
    How did you check? Keep in mind both lights have equal output.
    Many dealers do a quality-check themselves before shipping
    About 0,75 meters
  4. #34
    Flashaholic* vadimax's Avatar
    Dec 2015
    Vilnius, Lithuania
    Quote Originally Posted by daffie View Post
    So I did a second 'burn time' test with both the MH20 and MH20GT side-by-side (Nitecore 3400mAh, from 100 to completely off).
    This time both flashlights burn time on Turbo was exactly the same duration : 2h20.
    Somehow the manufacturer mentiones 1 hour burn time on Turbo, but in actuality it's double that
    Those lights are equipped with thermal management. Provide proper cooling (fan) and GT will run 1 hour, but on full power. Otherwise you are evaluating not the runtime on turbo, but ambient temperature in the test room
  5. #35
    Feb 2016
    Athens Greece
    Has somebody compare the MH20GT vs the P12GT? I ask,because I have the second one and if the 20GT is better by far,I could buy it.
  6. #36
    Quote Originally Posted by Theodore41 View Post
    Better is subjective but I chose 20GT over P12GT for the following reasons:
    - throw a lot more due to larger head
    - much shorter but P12GT is slimmer
    - 5 levels of brightness as opposed to 4 for P12 GT
    - UI with instant turbo or strobe from any mode (more practical than I thought)
    - USB charging port (not a deal breaker but a plus feature)
    - flat tail cap for standing which allows for adding a magnetic disc
    - group buy price was a no brainier (not sure about P12GT)
    The only thing P12GT going for me is the momentary tail cap switch for tactical use.
  7. #37
    Feb 2016
    Athens Greece
    Quote Originally Posted by jedi_master View Post
    Thank you for the response Jedi.
    I have the tail tactical switch,which is good,but has not the ability to use a lanyard with it,as there are no the convenient holes there.
    And something final.What about the tint of the 20GT?
  8. #38
    The 20GT has a hole for lanyard and it comes with one too. As to my knowledge, the 20GT is only available in cool white. However, there is a slight hint of yellow in the hot spot. I believe all XP-L HI has that. I also own ET TX25C with XP-L HI and it has lot more yellow compared to my 20GT.
  9. #39
    Dec 2015
    Vilnius, Lithuania
    I am color blind and noticed yellow hot spot only after making a photo of MH20 beam.
  10. #40
    very nice review how do you test battery voltage for this model?
  11. #41
    Quote Originally Posted by Chuoiz View Post
    Loosen and tighten the tail cap.
  12. #42
    Unenlightened
    Nov 2016
    thanks for the review.
    Can i put 70-71mm long NCR18650B Batteries with PCB and button top into the nitecore MH20GT ? the most recent ncr18650B with PCB are almost 71mm long.
  13. #43
    Unenlightened
    Nov 2016
    Quote Originally Posted by Pichpet View Post
    I will go out on a limb here and say that I think the spring/cap will bottom out and you won't get a reliable connection. My 69mm cell is less than 2mm from the outer end of the cap when I hold it side-by-side. I was afraid it wouldn't work first time it was installed.
  14. #44
    Jun 2016
    Corpus Christi, TX
    Yes it does fit. That's what I'm running in mine.
  15. #45
    Aug 2014
    Fairfax Va
    NCR18650B's are no problem at all. NCR18650GA 3500mah 10 amp cells are no problem either.
  16. #46
    Hi, 2 questions. My light seems to have a slight white circular line about a foot to 18 inches off the hot spot. Clear circle. So it doesn't go smoothly from the hotspot to the full spill is that normal or is my reflector bad? lastly, how do you get it in standby mode and how much power does it draw? thanks
  17. #47
    Unenlightened
    Jan 2017
    Colorado
    Another great review. I am sold on Nitecores' EDC flashlights. I just wish they came with a magnetic tail piece or made it easy to add one. I have been trying to decide between the EA11 and the MH20 but now you make it harder with this review. just kidding but it does make for another decision.
  18. #48
    Hello, I am looking to buy two of these for my elderly parents. Can anyone who owns the MH20GT tell me if there is a low battery warning light that flashes? I have read there is nothing to let you know the battery is getting low, but I have also read the blue light will flash once every 2 seconds when the battery gets to 50% and then increase faster as the battery drains more. Just trying to figure out which is correct. I understand you can get the battery voltage reading by loosening and tightening the tail cap which is awesome, but the low battery warning light is a must have for my parents as they will have no clue what the battery voltage reading even means.
    I have the Soonfire NS17 MH20 clone that cost $34 with a 3400 mah battery included and it has a red light that lights up when the battery needs to be charged so I was hoping a $100 light would have a similar feature.
    Thank You.
  19. #49
    Quote Originally Posted by LEDeez View Post
    Thank You.
    To part of your question, you have to press the button when off to get 1/2/3 flashes to indicate rough battery life (10%/50%).
    However... can I inquire why this would be the light for them? A pocket thrower is a bit of an odd choice for people with aging eyes who most often use lights for closer range use. My inclination is to go floody and rechargeable.
  20. #50
    Thanks. They are elderly, but can see fine. I bought them Fenix UC35's which they like for walking, but then I showed them my Convoy C8 with XP-L HI and they really liked the longer throw. I prefer my $20 Convoy over all my other expensive lights, but they need the USB recharging capability.
  21. #51
    Makes sense! Throwy lights are more fun!
  22. #52
    Quote Originally Posted by Bdm82 View Post
    My first light was a Fenix PD35 TAC and I loved it at first and though it was the brightest thing ever. Then I got some more throwy lights and like you said, they are just more fun. They make me go for walks more often because I just want to use them. The thing is the floody lights seem more safe for walking for them because they light up a wider path and not just a tiny spot, but I guess you gotta give up a little safety for some fun sometimes! lol
  23. #53
    Unenlightened
    Feb 2017
    Seymour, TN
    Nice review and great comparison shots! Was looking at the MH20 as a possible next purchase, but I think now it'll be the MH20GT after seeing how it performs here. Thanks kj75!
  24. #54
    Aug 2014
    Fairfax Va
    Had the GT since it was first released and still love it. Matter of fact I rank it up there on the same high plateau when it comes to compact lights as the highly lauded Zebralight SC600 MkIII HI. kj75's photos are spot on which is very impressive. As for spill the GT may not have as much spill as the XML2 MH20's but it still has enough for a good walking light. The GT is at the top of the pocket thrower game Nitecore really did a good job with it. I have all 3 MH20's and the GT gets the most use. The GA cell is perfect for the GT.
  25. #55
    This "Sickness" is getting really bad! Started out with a P-12, then a EC11 then a TMO6s and was about to order a P12Gt but I read this and just now ordered a MH20GT instead of the P12GT since its just as powerful but smaller but a lot more $$!
  26. #56
    Thumbs up Re: Nitecore MH20GT: XP-L HI V3,micro-usb, 1x18650, 362 meters, 1000 lumens, (beam)sh
    Got my MH20GT and to me at least it makes my P12 & EC11 almost obsolete, love it!
  27. #57
    Apr 2009
    Dallas, Texas, USA
    How does the beam, particularly the throw, of this light compare with a typical smooth-reflectored Convoy C8? Anyone own both?
  28. #58
    Tonight using a 3.7V 3500mah 18650 batt. in my MH20Gt set on Turbo it ran strong for 3 hours and 3 min before it died 100% and the batt. showed a 1% charge, This seems to be quite impressive and soon I will see as to how long it will run on high!
  29. #59
    Enlightened Screwball69N's Avatar
    Feb 2016
    Roaring Spring, PA
    Any new Promo going around on MH20GT if there is PM me pleas I want to get another 1
  30. #60
    Have had my eye on the MH20 for a while now, just cant decide if the USB charging port will become a huge point of failure for me. I wear a headlamp on my hard hat (NH60) where the USB charging port is sealed under a twist on cap so im comfortable with that, but my EDC light will see all sorts of O&G chemicals and temperature swings from -40 to 110 F. Thoughts on exposed USB port or no? Everything else about this light seems on point for what I would use it for daily.
