Hi all, BOLT ON light engines and heat sinks NOW AVAILABLE! 12 pc total remaining.
The contrast/brightness in this image is a little more intense than I remember it being in real
life, but the beam profile and crisp edges are about right.
Emitter options:
XM-L2 U4 1A
XM-L2 U3 3D
XP-L HI V2 1A
XP-L HI V2 3B
XHP-50 J4 1D (de-domed)
XHP-50 J4 5D (de-domed)
Driver options:
XML2 or XPLHI
1. single cell using the mosfet driver and Dr Jones Guppy2drv user interface.
2. 2 or 3 cell setup using RMMs buck driver. DrJones UI or options as listed below. Using guppy2 has no LVP.
XHP50
1. 2 cell setup using Mosfet driver and guppy2drv
2. 3 cell seup using RMMs buck driver.
Any of the above options would include Dr Jones Guppy2drv user interface.
User Selectable Groups:
RMM buck driver.
ship until the driver is completed. Features and Specifications:
Prices:
Heat sink only $65
XML2 light engine with Mosfet driver for single cell use $159
XHP50 light engine with Mosfet driver for 2 cell use $179
Add buck driver to either setup +$40
USA Shipping $6
World wide $14
Total available:12pc
Paypal is [email protected]
Complete heads ALL SOLD!
Price is $349 base. This includes ANY emitter and the MOSFET driver.
Price with BUCK driver is is $375
USA Shipping is $9 with tracking and insurance.
World wide is $16 for first class. $35 for priority with insurance.
Emitter options:
XM-L2 U4 1A
XM-L2 U3 3D
XP-L HI V2 1A
XP-L HI V2 3B
Driver options:
XML2 or XPLHI
XHP50
- 1% - 25% - 100% | Memory
- 1% - 25% - 100% | No Memory
- 100% - 25% - 1% | No Memory
- 1% - 25% - 100% - Strobe | No Memory
- 1% - 25% - 100% - Strobe | Memory
- 10% - 100% | Memory
- 10% - 100% | No Memory
- 100% - 10% | No Memory
- 100%
- Strobe - 100% | No Memory
- ML - 2% - 25% - 100% | Memory
- ML - 2% - 25% - 100% - Strobe - Beacon | No Memory
- ML - 100% | No Memory
- 100% - ML | No Memory
- ML - 100% | Memory
- ML - 1% - 5% - 15% - 40% - 100% | Memory
- ML - 1% - 5% - 15% - 40% - 100% | No Memory
- 100% - 40% - 15% - 5% - 1% - ML | No Memory
- 100% - 40% - 15% - 5% - 1% - ML | Memory
- 100% - 40% - 15% - 5% - 1% | No Memory
- 100% - 40% - 15% - 5% - 1% | Memory
RMM buck driver.
- Low-profile: only 6mm tall on the LED side.
- Nearly flat on the battery side
- Mode level options (see below)
- 2S-4S input voltage range
- Designed primarily with a 3V LED in mind, such as the XM-L2, XP-G2, XP-L, etc.
- Can be used with a 6V LED such as the MT-G2 or XHP50/XHP70, but the maximum drive current is 4A.
- Can be used with a 12V LED such as the XHP35, where the maximum drive current is 2.5A.
- Plenty of component clearance for retaining rings and a full ground ring for easy soldering
- Output Current:
- 2.5A (Maximum for 12V LEDs)
- 3.5A
- 4A (Maximum for 6V LEDs)
- 4.5A
- 5.1A (Maximum Recommended for XM-L2 LEDs)
- 5.5A
- Input Voltage:
- 2S (~8.4v)
- 3S (~12.6v)
- 4S (~16.8v)
- LED Type:
It is necessary to designate the LED type so that the components can be optimized for optimum efficiency for the given LED.- 3V LEDs: XM-L2, XP-L, XP-G2, etc.
- 6V LEDs: MT-G2, XHP50, XHP70
- 12V LEDs: XHP35
- Driver Program:
- MTN-MAX Standard: 4 well spaced modes. Moonlight, low, medium, and high/turbo.
- Single-Mode 100%: A single mode: 100% high only (with low voltage shutoff).
- CUSTOM: Choose your own modes (please put desired modes in checkout comments)
- 1 to 6 modes
- Ascending or descending mode order
- guppydrv Universal Rev.1: See the 17mm FET driver listing for guppydrv mode groups.
- ***NO LOW VOLTAGE SHUTOFF WITH GUPPYDRV---USE WITH PROTECTED CELLS***
- Memory: (n/a for guppydrv)
- Yes: remembers last mode.
- No: always starts in first mode
- Turbo Timer: (n/a for guppydrv)
- No Timer
- 30 Seconds
- 60 Seconds
- 90 Seconds
- 120 Seconds
- 180 Seconds
- Low Voltage Protection (LVP):
- 1. No LVP
- 2. 2S LVP (for 2S cells) - ~6V Ramp
- 3. 3S LVP (for 3S cells) - ~9V Ramp
- 4. 4S LVP (for 4S cells) - ~12V Ramp
Prices:
Heat sink only $65
USA Shipping $6
World wide $14
