I have a foursevens qp2a-x aka the 2 AA battery quark light from foursevens.
Ive had problems with it randomly turning off and refusing to come back on, as well as it not switching modes when pressing the power switch.
Im using enloop AA rechargables which say they are 1.2 volt batteries and regular AA batteries are 1.5 volts, could this be causing some kind of problem with the light?
Also ive sent it back to foursevens twice with the same issue and they have mailed me back the same light after tightening the pocket clip retention ring the first time, and
a ring inside the tailcap the second time. Im not that mechanically inept that I wouldent think of parts being loose before sending it back.
The light has probably used a total of 4 sets of AA batteries since I first bought it so im pretty damn sure its not wear and tear causing the problem either.
Have any of you had these problems with foursevens lights and do you know if enloop AA batteries cause it problems?
