hh4whiskey
- Joined
- May 21, 2016
- Messages
- 6
I've searched/lurked here for weeks. Tried every bit of advice I've seen. Tested, re-tested. I can't get ANY LES drop in to work on my old P6s. I've cut springs, removed springs, wrapped foil, meter tested, jumped wires, switched bodies/heads? I can throw the old PJ-3 Laser Products heads in, and they run fine. I've got some cheap LEDs and some good ones. They all run in other, 18650 lights, but not in the 2x123 lights, even though rated to beyond 6v. I'm new to the flashlight tinkering, but not to electronics in general, and the ONLY idea I have is: the ratings on these LEDs are off and they're incompatible with 6V? Need any help. FWIW, these are old weapon light bodies from 351/651 Beretta mounts, but convinced that's irrelevant?
Thanks.
Thanks.
