I was sure I had the very same issue. But...
My MH20 had been 'on the shelf' for maybe 10 months, when I recently wanted to put it back in service. Instead of using the micro-USB interface on the MH20 itself, I simply unscrewed the rear cap and popped the 18650 (NL1826 Nitecore 2600 mAH cell) into my Opus-C3400 to charge: I wanted to test the capacity of the Nitecore 2600 mAH battery supplied with it - as well as the two Nitecore NL189 3400 mAH cells supplied with the kit I bought from Amazon back in October 2016 - now seven years ago. (The C3400 charger / tester charges / discharges / then charges each of four cells completely independently. It also does < not-sure-how-reliable > Internal Resistance measurements.) Surprisingly, after seven years, these cells are holding up remarkably well: the two 3400 mAH cells measured 3294 and 3305 mAH, while the 2600 NL1826 cell measured 2633 mAH - actually higher than its rated capacity. IRs were still good, with all three cells measuring around 100 milliOhms based on multiple trials (trying to pay attention to minimizing contact resistance - to get consistent results). Not quite as good as some of my newer Samsung 25R / 30Q cells (which measured more like 50 milliOhms; but still very respectable for their age ...)
I digress. After topping up all three 18650s I put the original cell back in, screwed on the back cap again tightly - and pressed the on / off switch. That's odd. No blue lights from the switch button to tell me the voltage. Not a glimmer. Nada. Nothing. I kept clicking: zippo. I unscrewed the back cap and tried one of the other cells. Same non-result. I couldn't believe it; this light has always been super reliable and had never failed me.
I went to the internet, looked at videos. No joy. I came to this Candlepower forum. Sounded like my MH20 may have died?
I printed out the manual and read through it thoroughly...
Duh!*! The text reminds the user: "As a matter of good practice, when putting the unit away for an extended period, unscrew the HEAD a turn or so to ensure it CANNOT turn on while in storage."
HEAD? What about the head? There's yet another place to open the flashlight? Oh wait - that's right. In the intervening months since I'd put it away, I had forgotten that design detail.
But evidently - back early this year when I put it away - I had dutifully done just that.
Returning to the unit, I grasped the head. It did not seem loose, but I gave it a firm twist and Lo - it turned.
Problem solved. I felt like a fool - but returning to this thread, I wondered if that might be another possibility for one to try if experiencing this issue. So...
Talk about a long-winded way to get to the point - but hope it may be of some value to another MH20 owner.
