RCLumens
Greetings,
Was wondering if anyone has had any issues or fix suggestions for an Olight M22 that seems to have
a switching issue. As per the UI, I like to have the light set on lowest mode, then do a quick double
click to go into high mode as needed. The problem is that the high mode does not stay on - when I do the full press
it sometimes shuts off. Was wondering if there's any problems around this? I'm also using the Olight 18650's in the light as well -
Many thanks for any suggestions in advance.
