Curious. The ones that I know:
Surefire headlamps
Nitecore MH20
Manker T01, U11, E11
Zebralight have 4Hz Strobe/Beacon, if you call that a beacon..
Anything else?
Surefire headlamps
Nitecore MH20
Anything else?
Couldn't agree more. Quality is always my first criteria.... the first thing I would research would be the quality of the lights put out by the manufacturer. ... Some of the manufacturers you mentioned have a reputation for making solid, dependable lights and although they might cost more, it would be well worth it (in my opinion).
This beacon is somewhat different from the usual ones that I know (very short flash every, say a second). Do you have this light? how do you like the 1 sec beacon?Eagletac D25 Series have beacons (~1 sec on/ 10 sec off), in various battery configs incl 18650, and the D25A Ti is easy to rig on any battery with a paperclip (eg 18,000 mah D cell might run for days).
Zebralight has various lights with very long runtimes and beacon modes... they do not list runtimes for the beacon modes.... but, for example: the SC63w is listed at 18 days for 3.3lm L1... so I would have to imagine that the 0.2Hz beacon on Low would last for a loooooooooooong time.
Those very low output beacon can't be seen from distance, so is their function reminding you where the light is?Armytek Wizard Pro V3 XHP50
How's this for days.....7lm (12d), 2lm (40d), 0.25lm (200d)
There, Fixed it for ya. Hehe
That's a good pointedit: I'm also a believer in frequency = urgency (eg, strobe > emergency; steady blinking > warning; and 1sec every 10 secs > lighthouse-like FYI) and that higher frequencies might be more likely draw third party attention/assistance... then again, that may be your intention (which is still an option).
Just to clarify, the newer ZL have the 4Hz and 19Hz strobes, and two 0.2Hz beacons (1 flash ~every 10 seconds); one mode is whatever you have your low mode set to and the other is max brightness.Zebralight have 4Hz Strobe/Beacon, if you call that a beacon..
As for longevity... I can only assume that it will "run for days". But for good measure, my testing has NOW started. (Zebralight SC600 III HI) I'll update in 24 hours on how it's doing/battery life remaining.
Are you testing the 0.2Hz beacon on H1 mode? That will be interesting...
