darkzero modified some MiniMag reflectors for me and after trying them with a few different Sandwiches I'm posting my impressions.
The reflectors are two smooth and one OP. I'll say right up front the OP is the one I prefer due to the smooth reflectors having more artifacts than the OP. The smooth reflectors are pretty nice, but the OP are better yet.
I couldn't turn the light off by turning the head like you would on a stock MiniMag, but I was using Kroll switches so it didn't matter to me. I discovered this while I was focusing the light and I thought I should mention it.
I started with a pair of BB750 Lux3 TVOKs with Fraen Low Profile Optics in an attempt to level the playing field.
I used one with Fraen LP as a base line. The modified reflectors have a much different beam than the Fraen LP. The hot spot is a little smaller and less intense than the Fraen LP.
The reflectors have nice hot spot about twice the size of the hot spot of a PR with a Luxeon III. The beam reminds me of a PR, nice and smooth with lots of spill. The modified reflector doesn't have the throw of the PR but otherwise it's similar.
I also compared these to a McFlood. The modified MiniMag reflector was like a McFlood with a hot spot.
I also tried a BB500 R2H with similar results.
These were modified for use with high dome Luxeons, but I just had to try them with some low domes. I tried them with MM+ Q3 and BB400 Q3. There was still more tint in the beam than with a high dome, but the reflector seemed to smooth out the tint nicely. IMHO these are just as good with the low dome as they are with the high dome.
I saved the best for last. I tried both the smooth and the OP with a MM+ Cyan. The smooth had the artifacts of a colored Luxeon, but the OP has found a home with this Cyan Sandwich. The OP reflector gave the smoothest beam I've found for a colored Luxeon. It's not perfect but it is pretty good. So this story has a happy ending. I had fun and my Cyan Sandwich got just what it needed. I think these are a worth while addition to optics and the McFlood.
Thanks darkzero /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/thumbsup.gif
