I recently purchased a $3 dollar headlamp from harbor freight. This headlamp uses two AA cells that directly powers an incandescent bulb. I want to use a white output led instead of the incandescent bulb. The bulb has two small pins that can be pushed in or pulled out thus no soldering required. I will be using lithium or eneloop AA batteries. What led(s) do you suggest i try?
