Stevie
Bought an E12 for EDC purposes recently, it's just right for the pocket. However, not too happy with the beam profile as the LED seems off centre and the beam is a little 'wonky'. Also, mine seems to have an intermittent loose connection, only solved by severely over tightening the head (think major excessive torque here). When I first tried it with the supplied AA battery, it wouldn't light. So I changed out the battery and without thinking about it tightened the head very tightly, which solved the problem. Then yesterday I had intermittent mode faults, so by trial and error realised that it was not actually the power source, but a poor contact somewhere that was causing the issue.
Don't get me wrong, this is a £20 light in England (30$ USA?) and I'm not going to loose sleep over it . I do however own two other Fenix lights, more costly and what you might call a little more premium. Both bought a few years ago. There are no issues with these whatsoever and beam pattern is excellent on both. I just wonder if the low cost E12 is made in another factory where QC is not as good, or if generally the quality of Fenix lights has dropped? :thinking:
