djpark
I may say that this is my "serious" first mod if I don't count a kiddy Solitaire mod and making a few new ARC-AAA heads with different leds. However, I can't say it is a "real" mod, it is more of a "frankenstein" style.
Though I planned to do ARC-AA with Luxeon mod, I wanted to try a cheaper one as a practice - 8mm white led from ISP (16000mcd) on ARC-AAA head from dpr.
Sorry for the poor focus of the pictures, someday I hope to buy a better camera.
First, I had to widen the hole to fit the 8mm. Left is normal ARC-AAA head and right is 8mm hole in it. I polished the reflector, but it gives no difference to the beam.
Initially I wanted to use a regulator IC "MAX1797" from Maxim. They were generous to send 2 pieces for evaluation. It claimed to have over 95% efficiency and max 500mA. From the data sheet, I expected at least 200mA 5.0V output or 400mA 3.3V output with 1.5V battery voltage. Sounds very promising.
Test result was quite poor. Of course with long cables on the spider web, it would be wrong to expect something very good, but it failed to deliver more than 30mA to led from 1.5V input (both 3.3V and 5V output).
So I decided to stick it to Micro Converter from Sandwich Shoppe. It claimed to be current regulated and pump out 155mA from 1.2-1.6V input.
Again, I was quite dissapointed to find out that it only delivered about 80mA current to led (I tried 8mm and a Luxeon) from a fresh AA battery.
Anyone know what could be wrong, or is it supposed to give this much only? Or is there a way to pump more current to led?
After inserting the led to the head, I pushed in some silicon sealant hoping to make it a water proof. I didn't want to use epoxy since I may take the converter for other mod later. I didn't put it in the water, but the blow and suck test shows it is not waterproof, sigh!
Then the covnerter goes in, the head is done. I later pushed in the led a bit back to the head to reduce the light spill from the led.
Because the diameter of Micro Converter is a little smaller than ARC-AAA board, it moved to the size and also easily short the batter-in or led-out with ground on the head aluminum.
So I added a short wire along the edge of the board to make it a tight fit to the head and adjusted it to touch the battery positive contact only when the head is fully turned in to prevent the further turning in to cause shorting.
Drop battery, screw in, here it goes! The blank head I used is not anodized (?), so it is lighter color.
Beam shot at 1m distance from the wall. Left is ARC-AAA-P and right is ARC-AAA-8mm, both with fresh alkaline batteries.
This 8mm white led has 55 degree viewing angle and barely gives any spill. Compared to ARC-AAA-P beam, the overall corona size is smaller, but it has a bigger and tighter hotspot.
Beam shot at 2m distance from the wall. Left is ARC-AAA-P and right is ARC-AAA-8mm.
I haven't done the runtime test yet, I don't have equipment to measure the light output (not even relative value, would someone teach me a simple way?).
But it draws about 0.36A from a fresh AAA alkaline compared to 0.21A of ARC-AAA-P. So a rough estimate is to expect 2-3 hours compared to 5 hours of ARC-AAA. (just estimate based on propotion only)
After running for 1 hour, it is slightly warm but not really noticeable.
I was hoping to overdrive this 8mm led to 150mA (spec 100mA), but ended up under-drive at 80mA. I hope someone suggest me to achieve it.
DJP
Edit: URL for pictures changed.
DJP
