Hi there, what batteries are you using (brand/make)? What type of run time and what level using? Have you checked the cells voltage when removed or put on charge ?
These are Nitecore 2300mah 18650 batteries. I think it also says NL183 on there. When I bought the light, it was part of a kit, including the batteries and a Nitecore charger, and also a small flashlight as a bonus.
On a fishing trip using the TM16, there are 5? brightness levels and I use the middle one and also the brightest one, probably 50/50. I don't use it constantly, I have other flashlights but I do use it a lot. On a 3-4 hour trip, it might make it all the way and it might crap out. I have not checked voltage; I don't have a meter here anymore, I need to buy one.
This light/batteries was bought about 6 months ago.
Say, these are 2300mah and see other batteries with higher ratings. Like I have some for another light that are 4000mah. Does a higher number just provide more run time?
