lolmonkies
- Joined
- Jun 11, 2016
- Messages
- 13
I am stripping cells from old batteries. I have a large quantity (about 300 pounds) of 4 cell packs with most containing Panasonic NCR18650 2900mah cells. A good portion of the cells have some brown flaky stuff on the positive terminal that almost looks like the cells vented. They all came out of the packs though with 3.4+ volts. I charged about 100 or so of them now to 4.2v then discharged to 2.8 and they still have 2700-2800mah capacity. The discoloring on the terminal has me slightly concerned though. Out of 100 cells, not one tested bad, none got hot, none had high resistance, etc. Is it possible these cells were just overcharged at one point or got too hot for some reason? I assume they're fine to use considering I tested 100 of them thoroughly and the outcome was good?
Link: http://industrial.panasonic.com/cdbs/www-data/pdf2/ACI4000/ACI4000CE17.pdf
