I'm starting to have a wider range of optics available, so I decided to test them on my EDC Brinkmann 3AA mod.
I also did the following to show something I discovered about the old (but not useless as first thought) NX01 optic in conjunction with a 1W HD luxeon.
The mod is a Brinkmann 3AA, with a 1W Q2J, DD, from 3 NiMH cells. For this test, current was measured at 1A.
And the contenders:
The target is a white door in my office. Distance to target is 24". The frame coverage for these beamshots is about 24". I locked the shutter speed, aperature, focus, and white balance on my camera.
A note about the NX01 - as you notice, there is a ring around the NX01. I took the original brinkmann reflector, and cut the lip off it, then glued that to the front of the NX01 - it's a perfect fit. It allows me to back the NX01 off of the LED - which actually achieves a tight focus!
In fact, the NX01 (in my observations) will focus the beam as tight as the newly discovered Fraen LP that everyone raves about. However, focusing back down close to the LED will also give a nice (albiet somewhat blotchy) flood beam about twice the diameter. The ring I glued to the NX01 allows the optic to remain perfectly centered, and perfectly aligned with the LED to allow the focusing effect.
I also included the NX05 (so we can see how truly bad an NX05 is with a high dome), Fraen 6 degree, two small reflectors, and the reflector from a Pelican L1 (it actually makes a pretty nice flood beam).
And reduced to 3BPP to show intensity map:
Obviously, the Fraen 6 degree has the brightest hotspot, but it definitely doesn't fit the form factor very well. The NX01 de/re-focused easily equals the LP in brigtness (and is a tad brighter from what I see). The NX01 doesn't offer much side-spill in either case - the beam has a pretty distinct boundary.
The first two reflectors could probably have a bit of a brighter hotspot, as they are not trimmed down ideally.
It's too bad more light makers didn't pick up on the usefulness/focusability of a HD+NX01.
The NX05 seems to perform pretty poorly with a HD, given the choice of optics we have.
And the contenders:
