Changchung
Hi guys, easy question, can I run 2 groups of 2 Cree XHP50 in serie and this 2 in parallel with 4 18650 in serie direct drive?
Thanks
Thanks
Maybe pm matt(vestureofblood) or email vinh to see if possible if now one knows...................these guys do a good few mods and maybe able to help/advise
Good luck
Really would need a driver. Max forward voltage of the 6V XHP50 is 6.3 volts and doubled it would be 12.6V which is well under the 16.8 from 4 series 18650. If you run 2 12V XHP50 you would required a forward voltage of 24V. Can you not run 2S2P with the cells and run the XHP50s (6V) in parallel with a buck driver?
Any option work for me, Maybe I explain wrong, but this was my idea, run 2s2p Leds with 4 18650 in serie
