Thanks for all the feedback!
The clip is designed for the flashlight shown in the images you see below. You can securely attach and detach the flashlight from the clip with a simple pushing or pulling motion. I will provide pictures showing how the piston pivot piece connects into the rear soon. For now you can see the housing for the clip's piston in the rear of the flashlight in the rendered image below. The piston piece inserts and locks into this housing using a specially designed quick release canted coil spring.
You can see dimensions and battery type in the specs below, it is slightly larger than the S1/s1A, mainly due to the extra length required for this unique clip. It still comes in a small package pocket light.
I hope this answers you questions, feel free to ask if you have any more. I will update you with images of the flashlight and clip combination soon! :thumbsup:
I like it OP. Nice and innovative. So I am taking it the actual light is the size of an S1/S1A?
Looks interesting, but you didn't show it at all with the flashlight attached or explain the quick connect mechanism.
Impressive-what does the end piece do(looks like a miniature spotlight)...are you able to share the price point yet? Thanks...
is it for AA or AAA pocket sized flashlight
