Danielsan
I ask myself how i can do a runtime test on "turbo" mode because many lights have step downs after a certain time, there are lights with step downs after 3 minutes already. There are two possibilities, you have to reset the timer all the time which will take ages and you never know if its a step down cause of the temperature or cause of the battery itself. The other possibility is to not reset the timer but isnt that more or less the same as the runtime in high mode minus the 3 minutes in turbo? What would you do to measure the turbo runtime based on the lux values? I usually measure the runtime from start to the low voltage warning and write down the lux values every 15 minutes. Lights with temperature sensors are less problematic i guess, i would just use a fan to prevent them from stepping down.
