Hello everyone!
For sale my custom modification of JML2940/Cyclops/Thor searchlight. New - only tested.
150W and 14000 lamp lumens. Real world range: 600m. Excellent color rendering index.
Specs:
Light source
Philips ceramic short arc MH lamp (CDM-T-SA) 150W
- 14000 lumens
- neutral white 4200K
- 95CRI
Reflector
Stock with custom bulb holder. Smooth, 190mm diameter, glass lens
Battery
Li-ion 18650 20Ah, Samsung cells, custom made. Battery management system build-in. 50 minutes runtime.
Charger
4h recharge time, noiseless, small. Weight: 350g
Size
24 x 36 x 27cm (W x L x H) Weight: 4.2kg
Plastic + rubber housing, build in cooling fan and arm strap.
Display
Battery voltage and status LED
Dual power switches and industrial charging port.
Voltage display, status led and fan intake vent.
600m to mast in field, zoomed on right
Same place, different perspective, zoomed on right
Charger
Searchlight is designed to work continously. Start-up time is 45s, full brightness and color after 120s. Running time 50min. It needs to be cooled down for around 5 minutes before next turn on. Excellent light quality and power. Only one piece made by me.
Price: $500 + shipping and Paypal fee
Item is located in Poland (EU), worldwide shipping possible.
Contact:
PM or [email protected]
For sale my custom modification of Lightforce Blitz 240 searchlight. New - only tested.
100W HID, 9000 lumens and extremely good focus, 1000m real world range
Specs:
Light source
HID lamp 100W
- 9000 bulb lumens
Reflector
Stock with custom bulb holder. Regulated focus. Smooth, 240mm diameter, plastic lens
Battery
Li-ion 18650 10Ah, 14.8V Samsung cells, custom made. Battery management system build-in. 50 minutes runtime.
Charger
3.5h recharge time, noiseless, small. Build-in charge level display. Weight: 450g
Size
24 x 26 x 36cm (W x L x H) Weight: 2.15kg
Plastic + aluminium housing(lower part)
Display
Battery voltage
Voltage display and HID bulb.
Charge port on back and charger on right.
Mast is 1000m away, zoomed on right
Searchlight has quick start-up time(1s?). Full brightness after 20s. Runtime: 50min. It is quick restrike capable. Excellent throw and high output. Only one piece made by me.
Price: $400 + shipping and Paypal fee
Contact:
Specs:
Light source
- 14000 lumens
- 95CRI
Reflector
Battery
Charger
Size
Display
Charger
Contact:
Specs:
Light source
HID lamp 100W
- 9000 bulb lumens
Reflector
Battery
Charger
Size
Display
Battery voltage
Contact:
