charlieplanb
- Joined
- Feb 8, 2014
- Messages
- 171
I'm looking at a12v 10" light bar ,upgraded with 5w leds for a total of 100w.
The specs say 100w @ 4.1 amps,I'm not a 12v or LED wiz but I would have thought It was 8.3 amps.
So I email the maker and ask how this works out to 4.1 amp for 100w and 4a for 60w
Heres the reply,,,
5 Watt/Osram | 3 Watt/Osram | |
Total Wattage | 100 | 60 |
Amp Draw | 4.1 | 4 |
Led Quantity | 20 | 20 |
Weight | 6.6 LBS | 6.6 LBS |
Raw Lumens | 11,000 | 6,220 |
I dont know,,,Is this a legit answer??Normally your math would be correct however LEDs run a little differently than conventional lights.
LEDs run cooler than most lights and do not need to run at full capacity to put out a maximum amount of light.
The 100w is achieved by a mathematical equation taking the # of LEDs by the maximum wattage for each. The 10" Double Row Series light will actually be running at about 58w while still generating 11,000 lumens (14.1v x 4.1a).
