Parcgreene
- Joined
- Sep 17, 2016
- Messages
- 1
I've searched through the forum and can not find an answer to what i'm certain for most of you is a very easy. I admit my complete ignorance and appreciate any help.
my problem-- So i have a 7 led flashlight that runs on 3 -3.7 volt 26650 batteries. I attempted to remove the head of the flashlight and wire it through a pvc tube to place the battery tube (powersource) further away. About 3.5 ft away from the flashlight head. I used thick 12 guage wire and it appears i fried the circuit board. Any ideas on what i did wrong and how to correctly determine the proper wire size needed?
product specs:
Description
Features:
* This torch uses of a 7x CREE XM-L2 LED, producing very bright beam of light.
* Output bright can come to above 12000 lumens(lm)
* Internal wiring applies the high efficient booster circuit,and can utilize the batteries in the largest extent
* The body of this flashlight is built of aircraft-grade aluminum alloy, and it has a very solid construction.
* Hard-Anodized finish; Anti-abrasive, free-scratch, shock-proof.
* Ultra-deep trench structuresi Skid-proof effect is excellent when diving
* This flashlight uses a textured reflector(rather than smooth reflector).The beam from a textured reflector is more even, with a more gradual transition between the hot spot (the center of the beam) and the spill (the periphery of the beam).
Specification:
* Emitter Type: CREE XM-L2 LED
* Light Color: White
* LED Quantity: 7
* Waterproof: Under water 50 to 100 meters
* Battery Configurations: 2pcs 18650/2pcs 26650/3pcs 18650/3pcs 26650 Battery (Not Included!)
* Voltage Input: 8.4v
* Switch Type: Twist
* Modes number:Low > High > Stroe
* Mode : To adjust the brightness gradually
* Brightness: 12000 lumens maximum brightness
* LED Lifespan: 100,000 hours
* Material :Aluminum
* Lens: Coated Glass Lens
* Reflector: Aluminum textured reflector
* Casing Color: Army Green
* Size(mm):223/(290 if plus the extend tube)L * 63(TD)*40(WD)
* Weight: 500g
Packaging Contants:
* 1x 12000Lm Scuba Diving 7x CREE XM-L2 LED Torch (Battery Not Included)
* 3x Battery Convertion Tube(When use the 18650 Battery)
* 1x Extend Tube
product specs:
Description
Features:
Specification:
* LED Quantity: 7
* Weight: 500g
Packaging Contants:
* 1x Extend Tube
