witness
I recently bought the Olight S1 Baton and, right out of the box, have been having nothing but problems with the light, the replacement that Olight sent me and the two Olight rechargeable 650mAh RCR123As that I bought with it. I've never had an Olight before and maybe these products are just more finicky than any of the other lights and batteries that I own. Here are the issues I've been having:
1) Both the first S1 that I got and it's replacement stop working properly after about 10 minutes of use (on high) with a fully charged Olight RCR123 battery. After roughly 10 minutes of use the next time I turn the light on (high) it cuts out in less than a minute and then won't turn back on. This happens with both the first S1 and it's replacement and both Olight RCR123 batteries.
2) Regular (non-rechargeable) Surefire 123A's don't seem to exhibit this problem but, so far, I've only tested to see if they can withstand 10 minutes of use without misbehaving like the Olight batteries do.
3) The 750mAh AW RCR123A's that I was told would work (by Going Gear) only work in the replacement S1 (but not the first one). What's that all about???? In the S1 that they do work in, they also seem to work OK, but like the Surefires, I've only tested to see if they don't misbehave after 10 minutes of use.
There seems to be issues with both the batteries and the lights. Can anyone shed some light on this?
