Hi, new on here, had a search about these, but only one thread from 2005 came up. Looking for some advice on a project i am about to do, which is upgrade the rechargable torch from an older bmw e46, this is a fairly standard item on the older models.
The batteries had gone on both of mine, 2x varta v250h cells, and needed replaced. After cutting it apart and pricing up replacements for both sets of batteries around £15, i looked at bulb upgrades for the e10 incandescent bulb. I found the following e10 bulbs which looked promising.
http://www.ebay.co.uk/itm/1X-LED-1W...768826?hash=item3f66a1073a:g:J-0AAOSwyKxXhFVI
http://www.ebay.co.uk/itm/1x-CREE-3...728555?hash=item3f66a069eb:g:~uwAAOSwanRXhEvu
I then realised the batteries were 2.4v, and the minimum voltage for these was 3v, so I am guessing they wont work? Also the bulbs had a positive earth, so i would need to modify the circuit to make them work. I then found a similar bulb with swiching polarity, and a minimum 1 volt neededed
http://www.ebay.co.uk/itm/NICELITE-LED-LIGHT-BULBS-BICYCLE-CYCLE-LAMPS-FLASHLIGHTS-TORCHES-MAGLITE-CREE-/252527200107?var=&hash=item3acbcb476b:m:mgDUxO72a7Xke2B2ocxo8CA
These looked promising, but the project was going to cost me £40 for the 2, which made me think i could build something better for cheaper, with a little help!
here is a pic of the internals of the torch...
The two pins take the 12-14v from the car, and the circuit converts the power to charge the 2.4v battery pack. there is not a huge amount of room, as i have shown an AAA battery to scale. My first thought was to change the batteries for standard, add in a small boost circuit such as this, to power an led and driver intalled in the original location.
http://www.ebay.co.uk/itm/1-5-3-3-3...566471?hash=item41b0a65ac7:g:DvcAAOSwU-pXsTTx
Then I thought about ripping out the circuit, and installing a small nicd pack like a cordless phone pack or similar with suitable charging circuit, then adding a suitable converter to go to the led driver and bulb. The front opening is about 15mm, so a lightly modified cree bulb such as an xm-l2 would fit.
The problem is I am a little lost when it comes to this stage, I have spent a few hours researching, but no idea what i should be going for, plus my knowledge of cars is far greater than that of electrics/leds! I do enjoy a little project and making something custom. If anyone could point me in the right direction, it would be much appreciated, I am more building a torch from scratch this way rather than modifying it now! I just thought for less money than upgrading, i could make something better. The torch does not need to have a huge runtime, but would actually be useful if it was a lot brighter, for things like looking in the engine bay at night. the dimensions of the space i have to play with are about 45 mm x 31mm, and about 15mm depth in the unit, or 1 3/4" x 1 1/4 x 5/8". Any suggestions on battery packs, leds and drivers would be greatly appreciated, thanks, allan
