HDS Systems
Results 1 to 7 of 7
Thread: Fire-foxes ff4 failed need a replacement ASAP
    Default Fire-foxes ff4 failed need a replacement ASAP
    I was thinking about the thrunite tn34 ut of the olight x7 as a replacement and are these the best
    about at the moment I have been off the scene for 2 years
    thx
    steve
    ven's Avatar
    Oct 2013
    Manchester UK
    Default Re: Fire-foxes ff4 failed need a replacement ASAP
    What do you want it to do?
    tn36UT=flood
    tn40= throw/flood
    tn42=throw
    x7=flood
    I would say the tn40 or tn42 seems more suitable if it is an FF4 replacement imo
    tn36UT=flood
    tn40= throw/flood
    tn42=throw
    x7=flood
    I would prefer throw as I can spot my dogs on the fields at night
    If size is a concern, I have been considering the Manker MK34. It is the first light that is comparable size to the zebralight sc6330. Seems to have some good reviews. 3 quads, each powered by their own 18650, so like the ZL, you can use the llight with only 1 battery. 55mm diameter at the bezel x 98mm long. XPG @ 8000 lumens or Nichia 219 @6500. On turbo, drops to 2000 lumens after a minute and will stay there for almost 2 hours...
    Quote Originally Posted by DMS1970 View Post
    Will check it out I'm spoilt for choice lol
    Flashaholic* aginthelaw's Avatar
    Jan 2007
    NJ, USA
    tn32ut, k60, k70 are larger lights, but are tops for throw. i think the tn30 has more throw than the tn36ut
    a single sunbeam is enough to drive away many shadows- St. Francis of Assissi
    I don't use my FF4 much, but it's a lot of fun and I worry about this. There are certainly impressive LED lights, but they're not quite the same.
